131
3
#425769 - 21/04/06 07:21 PM
Re: Relocating bottom rear shock mounts to axle...
Got 'er DONE! Pics coming soon.
#425770 - 21/04/06 07:28 PM
Loc: Windham, NH
Bastard!! Can't wait to see....it may change my plans...
#425771 - 21/04/06 07:38 PM
Originally posted by spalind: Bastard!! Can't wait to see....it may change my plans... It just might. I shot some pics w/o the shocks so you can see everything we did. There's a lot of room under there there now.
#425772 - 22/04/06 05:03 AM
Loc: Windham, NH
Originally posted by Editor X: Originally posted by spalind: [b]Bastard!! Can't wait to see....it may change my plans... It just might. I shot some pics w/o the shocks so you can see everything we did. There's a lot of room under there there now. [/b]And????? Jeez...woke up this AM and first thing I did was come here to see if there were any pics...how dissapointing....
#425773 - 22/04/06 11:56 AM
First set of pics. Lower mount driver side. Lower passenger side. Upper mount on DOM crossmember. The ends of the ubolts still need to be cutoff shorter to be a little less than flush with the bottom of the ubolt plate. The upper mount is 1/4 wall DOM tubing (think shrock sliders) and mounted on 1/4 plate brackets that are then welded to the frame. The whole crossmember takes the place of the one that held the spare tire and it much stronger. The box also was relocated to the new crossmember and a new piece of exhaust pipe was needed to clear the area for the shock. We cleaned up the underside by removing all the brackets for the sway bar (like I was ever going to use those again) and the old upper shock mounts that were on the frame. I'll have final measurememts later today after I articulate the rear, but from what I can tell the 12 inch shocks I had would have fit very nicely. I might be able to get a 14 inch shock in there, but I'm waiting to see first. I can see there is a lot more space to fill over stock even without measuring though.
#425774 - 22/04/06 04:34 PM
Ed, is that the TC lower relocation bracket? Paint - Rattle can/Powder coated?
Who is doing the work/welding?
Did you do any frame strengthening/gusseting where the upper cross member is hung since there will be the added stress there?
Were you or whoever is coming up with your measurements able to seperate the leaf pack down to just one leaf and cycle it to get shock length measurements?
What are you looking at for compressed/extended lenghts?
Are you going to be running the SAWs on the rear as well? Bypass or smoothy w/resi?
Are you going with the Baja bushings as well?
#425775 - 24/04/06 10:35 AM
No on the Baja Bushings.
Jeff at Deaver strongly discourages their use on street driven vehicles due to wear issues. Ed, I know you've spoken to someone that has run them over time on the street but Jeff also said he's had guys that ahve had them wear after as little as one race.
I'm going to wait until I see how long they actually last in daily street/dirt use and what the indications and results are.
#425776 - 24/04/06 11:16 AM
Loc: Windham, NH
I'm going to wait until I see how long they actually last in daily street/dirt use and what the indications and results are. Nice...will cross that off the list of considerations....think there is the same issues with the orbit-eyes?
#425777 - 24/04/06 12:24 PM
That's why I like the Revolvers...like stock until you need them...and they twist as needed to take the stress off the leafs in torsion.
#425778 - 24/04/06 06:44 PM
Originally posted by socalpunX: Ed, is that the TC lower relocation bracket? Paint - Rattle can/Powder coated?
Are you going with the Baja bushings as well? Here are some short answers for you. 1. A local offroad shop. TC has Dan's race rig in now and can't fit me in the schedule. 2. Gussets are there. 3. No on the leaf packs. 2 fork lifts at Home Depot got the job done. 4. Shock length is 16.5 and 26.5. Running the SAW piggy backs in 2.5 dia. body. See other post for reasons. 5. No on the bushings.
#425779 - 25/04/06 08:02 AM
Loc: Windham, NH
Originally posted by Editor X: Originally posted by socalpunX: [b]Ed, is that the TC lower relocation bracket? Paint - Rattle can/Powder coated?
5. No on the bushings.[/b]How'd you get the forklifts at HD to do that for ya?? couple buddies who work there?? And I'm not needing super beefy shocks like you is the reason the Bilsteins were fine by me...You do alot more highspeed prerunning/desert style driving than I do....no wide open spaces around here to go running on so the 2.0 Bil's with remote reservoirs should be fine for me...My shocks should be in this week so I probly have like another week and 1/2 to go before I get any welding done...
#425780 - 26/04/06 06:06 AM
Scratch the 10 inch shock. Going with the 12's. They will fit just fine. 19.5 collapsed and 31.5 extended. Usind the SAW Racerunner 2.5 dia. Piggybacks.
#425782 - 02/05/06 09:17 PM
Very shiney. I'll have to shoot a picture of mine so you can see them.
#425783 - 03/05/06 05:42 AM
Loc: Windham, NH
Originally posted by Editor X: Very shiney. I'll have to shoot a picture of mine so you can see them. Yes....yes you will....
#425784 - 08/05/06 11:39 AM
Loc: Windham, NH
OK...ordered my rear leaf pack from Calmini....for $299 you can't beat an entire replacement for the rear leafs...plus I don't do nearly the highspeed running that you west coast guys you, so if they are bit more suited for slow speed crawling thats fine by me...They had them in stock and should be here in about 10 days..... Calmini SAS rear leafs..
#425785 - 17/05/06 05:07 PM
Loc: Windham, NH
Leaf springs are in!! Very fast shipping, good customer service from Calmini....Very happy...now for the welding and such...
#425786 - 17/05/06 05:15 PM
Nice! Dan, let me know how they work out. I've been looking at these. The price is right.
#425787 - 17/05/06 05:45 PM
I've had the SAS leafpacks on for a coupla' few months now and have used them mainly offroad. They are firm but not stiff, and you'll still get the droop too. They are a vast improvement over any other rear susp mods I'd tried previously also. There's the slightest bit of rake as well, which can only be righted using a SAS...But I think it looks great and handles perfect offroad too Edit to add- Signed, Dan
#425788 - 17/05/06 05:51 PM
Originally posted by DBAX: There's the slightest bit of rake as well, which can only be righted using a SAS... They can also be dearched.
#425789 - 29/07/06 12:23 PM
Loc: Windham, NH
#425791 - 29/07/06 02:47 PM
x2
#425793 - 02/08/06 09:19 PM
What lift are you running up front?
When I looked at DBAX' pics it didn't look like he had nearly the rake that you do. Your X seems way high in the back compared to his even though you're both running the same rear springs.
Did the Calmini SAS springs change in some way?
Edit to add that it's good to see your project working out for 'ya.
