#425914 - 21/12/07 05:03 PM shackles or add-a-leaf?
i want to turn my torsion bars and i also would like to jack up the back to match, i would just like to know what would be better, an add-a-leaf kit or shackles. i know shackles are cheaper, i just want to know what would be better in the long run, i do light to pushing the 2wd to the limits of 2wd, so what would be stronger in the long run?
#425915 - 21/12/07 05:09 PM Re: shackles or add-a-leaf?
The shackle will give you better articulation over an AAL, but an AAL will give increased load capasity over the shackle. Which one do you want?? Your other option is a new spring pack made to your specs so that you can get whatever you want.
#425916 - 21/12/07 07:54 PM Re: shackles or add-a-leaf?
Well, if I had to run a 2wd off road...I'd ABSOLUTELY get longer shackles over AAL.
A 2wd HAS TO keep its tires on the ground...and that means articulation. AAL's KILL articulation by stiffening the pack...so your tires can't stay on the ground.
A shackle allows swing, letting the pack flex and reach the ground better.
A shackle will not sag...an AAL can sag with time (Most do sag with time...)
So - if you want a reliable rear PML lift...get AC's 6.5" eye to eye shackle.
