#426091 - 30/07/02 06:12 PM alignment question
HandyX Offline
Loc: Columbus Ohio
Just got new boots (31 BFG AT/KO). Had the alignment done at tire kingdom (Mueller Tire&Brake).
Camber is .8 (left) .7 (right)
Caster is 2.5 (left) 2.4 (right)
Toe is .15 (left) .16 (right)
Cross Camber is 0, cross caster is .1, total toe is .31 degrees.
What is SAI? According to their computer it's
9.6 (left) and 9.8 (right) - computer said it was out of spec. Is this something that can be adjusted to be within specs?
My X seems to ride fine .. anyone know if this is anything to check out?
#426092 - 30/07/02 06:43 PM Re: alignment question
WheelOhio Offline
Loc: Columbus, OH
Just out of curiosity:
1.Is your truck lifted? What AARMS?
2.Was that the closest your tech could get it on the Camber?
just curious..thanks
MVM
When faced without a challenge, invent one.
#426093 - 30/07/02 06:45 PM Re: alignment question
HandyX Offline
Loc: Columbus Ohio
Sweet wheels WheelOhio! I haven't made any lift or suspension mods. Just a little rubbing when turning sharp and braking. Might do a T-bar adjustment 3 or 4 turns. What part of Columbus you from?
Noticed the specs for included angle should be 10.4 - 12.4.
Left is 10.3, right is 10.5 ..is this something that playing with the other adjustments usually fixes?
Again doesn't seem out of wack .. The reason I'm asking is, I'm planning on driving 1200 miles in 2 weeks, didn't want any uneven tire wear...
