#426446 - 06/12/05 10:09 PM Bilstein Steering Stabilizer
dezurtrat Offline
Loc: Tucson, AZ
OK, here are the steering stabilizer (from AC) pics. Thanks to Shmittey over at XF for his great pics which helped me allot! The instructions have allot to be desired!
You’ll notice the shock isn’t parallel to the center link as it’s supposed to be but as you see in the second picture that is so the L-Bracket with the U-Bolts can clear the sway bar bracket. The second picture is with the wheel cut all the way right.
I checked it with the steering full right and full left both on the stands and on the test drive and it feels good and no binding whatsoever!
#426447 - 06/12/05 10:27 PM Re: Bilstein Steering Stabilizer
dude...what do you have done on the insides of your stabilizer bar? confused
#426448 - 06/12/05 10:33 PM Re: Bilstein Steering Stabilizer
dezurtrat Offline
Loc: Tucson, AZ
I'm not sure what you're looking at. In the second pic down to the left is the idler arm brace. Is this what you are referring to???
EDIT: Maybe you are looking at the grommets sticking out on the inside of the sway bar brackets! If so, they look funny in the pic but otherwise normal!
#426449 - 07/12/05 10:43 AM Re: Bilstein Steering Stabilizer
conker69 Offline
What exactly does this do?? Where did you purchase it??
#426450 - 07/12/05 11:46 AM Re: Bilstein Steering Stabilizer
dezurtrat Offline
Loc: Tucson, AZ
It dampens out road bumps, wind surges on the highway, and things like that. It just slows down the steering response to any jerks in the steering.
It gives you a tighter feel to the steering. Very nice actually! The X seems to have pretty responsive steering and it helps out with that.
4x4parts.com
I purchased this one but you can buy just the stabilizer without the idler arm brace.
Steering Enhancement Package
#426451 - 07/12/05 04:48 PM Re: Bilstein Steering Stabilizer
4x4parts.com
Got the same setup myself, not life changing but an improvement. I like the feel of it, seems to smooth things out. Big difference on the highway with high winds.
#426452 - 07/12/05 07:07 PM Re: Bilstein Steering Stabilizer
dezurtrat Offline
Loc: Tucson, AZ
Thanks for all your great pics you sent me on your install Shmittey!!! [ThumbsUp]
#426453 - 28/12/05 02:36 PM Re: Bilstein Steering Stabilizer
This post help convince me to get the stabilzer for my X. It was one of my "X"mas gifts from my wife.
Can't wait to install it.
Rob
#426454 - 28/12/05 03:23 PM Re: Bilstein Steering Stabilizer
Congrats, you will like it laugh
#426455 - 28/12/05 07:08 PM Re: Bilstein Steering Stabilizer
dezurtrat Offline
Loc: Tucson, AZ
Wooo Hooo! Nice. Give us a shout if you have questions about the installation! smile
#426456 - 01/01/06 05:03 PM Re: Bilstein Steering Stabilizer
Is this a install that I can do in my driveway with hand tools ? It looks like a nice unit ,Thanks
#426457 - 01/01/06 06:59 PM Re: Bilstein Steering Stabilizer
Yep, very easy to do and takes only around 1/2 hour or so depending on how rust welded your bolts are.
EDIT: you have an 06, they dont make one for your setup yet frown
#426458 - 02/01/06 04:11 AM Re: Bilstein Steering Stabilizer
Thanks Shmittey I did not realize it was not for my 06 I guess I'll have to wait
#426459 - 02/01/06 12:46 PM Re: Bilstein Steering Stabilizer
dezurtrat Offline
Loc: Tucson, AZ
Oh bummer man! Good catch though Shmittey ! laugh
#426460 - 04/01/06 08:51 PM Re: Bilstein Steering Stabilizer
After I put the shocks on the X I decided that I might as well put the steering stabilizer on too.
This thing went up so easy! The only problem that I had was a defective ubolt. Snapped the damn thing off as I snugged the nut. (Now that sounds really painful) Got a new ubolt at Lowe's and all is well.
This makes such an improvement to the feel of the steering. As I drove to see my new daughter at the hospital it felt like a totally different truck, a more confident feel to the steering. I highly recommend this to anyone out there.
Just glad I read the great posts about this. Thanks guys.
Rob
#426461 - 04/01/06 08:54 PM Re: Bilstein Steering Stabilizer
dezurtrat Offline
Loc: Tucson, AZ
Nice job! Congrats! smile
#426462 - 05/01/06 08:33 AM Re: Bilstein Steering Stabilizer
Are those 32 inch tires your running now? Just wondering because all I have ever read on this forum is that a steering stabilizer does'nt serve any purpose with tires smaller than 32's. Hence the reason factory 00-04 X's don't come with them. It looks sweet though, good job.
#426463 - 05/01/06 08:53 AM Re: Bilstein Steering Stabilizer
I have stock 265/70/16s and it made a difference.
#426464 - 05/01/06 03:41 PM Re: Bilstein Steering Stabilizer
i want to get bilsteins all around plus the steering stabilzer. My question is, do you guys recomend getting the idler arm brace? becuase it is 30$ cheaper without it. Im not going to do any serious offroading are tires larger than 31's so i dotn think i need to worry about breaking anything. Any input?
#426465 - 05/01/06 03:49 PM Re: Bilstein Steering Stabilizer
I got the steering brace along with the steering stabilizer kit from AC. While it serves the purpose, it is pretty ghetto if you ask me (2 pieces of angle iron welded up with a couple holes drilled in it.) Had I known how it was made I would have bought a different one. But I would definitely get a steering brace from somewhere, the steering is one of the weakest links in the X and $30 bucks is a pretty cheap way to help it last.
#426466 - 05/01/06 06:20 PM Re: Bilstein Steering Stabilizer
dezurtrat Offline
Loc: Tucson, AZ
Same here!!!!
#426467 - 05/01/06 09:09 PM Re: Bilstein Steering Stabilizer
I have 265/70/16 BFG's also. And I too will add that it made a difference. I have the Calmini idler arm brace which when I did comparisons looked to be better engineered in my opinion. Laser cut, bent, welded, and a beautiful blue color to boot!
The brace is a reinforcement and if you really want to see why to get the brace, just pull the idler arm off of the post and see how much isn't there supporting that arm. All it really takes to bend/snap that arm is catching a tire in just the right freak situation.
Rob
#426468 - 05/01/06 09:15 PM Re: Bilstein Steering Stabilizer
dezurtrat Offline
Loc: Tucson, AZ
Yea, I agree there! Here is my AC idler arm brace. smile
#426469 - 14/01/06 04:19 PM Re: Bilstein Steering Stabilizer
BlueSky Offline
Loc: Georgia
I'm kind of intrigued by this thing. Those of you who have had it for a while, what's your take? Does it really make a difference? If so, how specifically? I've read the thread but what does "a more confident feel" mean?
#426470 - 14/01/06 04:55 PM Re: Bilstein Steering Stabilizer
I am pretty happy with it, tell you the truth I don't remember what it was like before I put it on. Highway driving is much better, less squirly with winds, potholes and big rigs. I am not fighting to keep it in the lane anymore.
Edit: I assume you are talking about the steering stablizer and not the IA brace, right?
