Originally posted by Mike H:
Probably a stupid question, but should the length of the end link extension (spacer, bolt) be proportionate to the amount of lift you install? Or is it not really possible to add that much extension?
If one of the engineers on the boards wants to chime in, maybe they can answer this better...but remember that the swaybar anchors to a part of the A-arm much closer to the pivot (where it bolts to the frame) than the wheels do. The lift kits allow you to run a higher angle on the A-arms, so the new distance from the lower a-arm to the swaybar in its nominal position would be increased, in an ammount proportionate to, but not equal to, the amount of total lift you have.
Here's a (bad) diagram that may help. The straight red line from the lower a-arm to the swaybar is where the endlink would be.
