#427322 - 14/01/07 10:39 PM SLR Econo Steering
So does anyone actually have this steering? if so what do you think. I like the LP or SLR econo centerlink set up but I think LP are having some problems.
#427323 - 15/01/07 01:15 PM Re: SLR Econo Steering
It looks great but it only addresses the IA side of the centerlink and has the same IA as the full system. food for thought, the FULL SLR steering kit is only $174 more after core charges and you get a whole new centerlink with IA and PA. We were going to install both systems yesterday (different trucks) but did not get a chance to.
#427324 - 15/01/07 08:03 PM Re: SLR Econo Steering
I too would like to know.
#427325 - 15/01/07 08:53 PM Re: SLR Econo Steering
I will ask Sven to chime in once he gets the system installed.
#427326 - 17/01/07 04:09 PM Re: SLR Econo Steering
As soon as I get it in, I'll post up.
In general, I went with the econ because I'm only doing a 2" SL right now, which means that I'll only be able to go up to 32's for the time being, which in turn means that I won't stress the steering as much as I would with 33's or greater.
If I end up getting a BL at some point and will run larger tires as a result, then I'll swap out the econ system for the better one. At that point, my X won't be my daily driver so I should have more time to do the things that would warrant the extra cost.
#427327 - 14/02/07 08:35 PM Re: SLR Econo Steering
I got this steering installed on my truck and love it. My truck now goes straight without fighting with the steering wheel from all the previous slop.
#427328 - 18/02/07 08:02 PM Re: SLR Econo Steering
is this steering worth it, since it only addresses the idler arm side? I was thinking about this but my go with the full SLR and idler arm shaft as well...
Thanls
MArk
#427329 - 18/02/07 08:40 PM Re: SLR Econo Steering
Rockaholic Offline
Loc: Reading, MA
Thanls
MArk
I still haven't heard of anyone having a problem with their Pitman arm.
Centerlink faling - yes
Idler arm failing - yes
Pitman arm failing - no
Jeffrey
#427330 - 19/02/07 03:13 PM Re: SLR Econo Steering
thats the answer i was lookin for thanks a lot ^^^
