#427610 - 12/06/04 07:33 AM Torsion bar up about 3/4 ", now a driver's side clunk
Greetings,
Not sure what's going on here, but this is the story.
I installed BFG KO A/T, 265/75/16, and cranked the torsion bar to add about .75" more height. Incidentally, the number of turns was significantly more than others I have read about - I'm guessing about 12, but I was paying more attention to the measurement from frame than anything else.
I also installed Shrockworks sliders, though I doubt this has anything to do with it.
Anyway, now when going over a bump I hear a clunking sound coming from what sounds like the rear driver's side tire area, but difficult to tell. It almost sounds as though something is bottoming out, but I'm surprised that if its a broken shock it would be a rear one rather than a front shock.
I do plan on eventually replacing shocks with Bilsteins, but need to do the same in my Alfa first, and I'm not exactly made of money.
Is there something else I might want to look at? Any recommendations would be most appreciated.
Thanks.
#427611 - 12/06/04 08:39 AM Re: Torsion bar up about 3/4 ", now a driver's side clunk
Did you double check your slider on that side with the sound? When I installed my Shrockworks they would appear on (because of their weight) and tight but weren't. I used locktite and sinched those suckers on good.
#427612 - 15/06/04 04:34 PM Re: Torsion bar up about 3/4 ", now a driver's side clunk
Any better ideas with this problem?
Yes, the sliders are securely fastened.
#427613 - 15/06/04 07:22 PM Re: Torsion bar up about 3/4 ", now a driver's side clunk
patrickmb Offline
Loc: Half Moon Bay, CA
Is your rear sway bar still connected? In either case, check the all the bolts there and/or the remaining dangling peices, if its unconnected now.
~See you on the boards, on the highway and in the dirt. -Patrick
#427614 - 15/06/04 10:36 PM Re: Torsion bar up about 3/4 ", now a driver's side clunk
Try tightening the front crossbar, at the front of the diff. 17mm I believe. Looking at it from the front, you'll see two per side. You'll actually be looking at the nuts of the crossmember there. Tighten the hell out of them! Sometimes, they can cause a sound similar to what you're describing.
