131
3
#428175 - 16/08/07 07:32 AM
Need help with shocks please!
Loc: iowa
It's time for some new shocks for my 2002 4wd Xterra. Non lifted. I can't seem to find anything that fits. I was hoping to find some 10% Bilstein or some rancho 5000's but when I called both companies they said they don't have anything for the 2002. Could someone please tell me what would fit this? I am under the impression that the 2002 shocks are specific.
#428176 - 16/08/07 10:30 AM
Re: Need help with shocks please!
I am going to buy some Bilsteins as well, and have done a little research on them, and here is what I found out driect from Bilstein.
For the 2002 X 4WD: Rear - BE3-6422-H0 Front - B46-1099-H2
If you have a 2wd, then use these on the front: B46-1099-H1
I'm going to buy mine from eshocks.com in the next week or so.
Hope that helps in your decision making.
#428177 - 16/08/07 01:28 PM
Theres a guy that sells the set for 245.00 w/ free shipping on ebay..check them out. He's in cali somewhere but he got them to me in less than a week.
#428178 - 16/08/07 07:19 PM
i bought them from the guy on Ebay too!! Great deal!! And for my fellow canadians he ships USPS too(no extra fees). I love them! Easy to install as well! later
#428179 - 19/08/07 08:37 PM
Just a pointer - The 00-04 X's shocks are all the same...the 2002's are not different.
#428180 - 20/08/07 02:53 PM
I'm confused now. Is there a spec sheet that decodes the Bilstein part number?
The number for the fronts looks familiar...B46-1099-H2. I usually see B46-1099-H0 for a lifted x, 20% stiffer.
The rear part number is new to me BE3-6422-H0. Shouldn't it be B46-2126-H0 for a lifted x, 20% stiffer?
#428181 - 20/08/07 04:15 PM
Shot of the rear Bilstein 5100 for altered suspension, 20% stiffer than stock. Bilstein's Part #'s: Front - F4-B46-1099-HO (Very Short Yellow Shocks, with Piston Compression Bumper, about 2" before they hit the piston bumper, and only 4" total travel if I take off the bumper (Which is about 2" thick) Rear - BE5-6216-HS (Much Bigger Silver Shocks, no Piston Bumper, about 10" of travel) (SLR) shocks were for a 3" suspension lift with 20% stiffer ride: Above SLR #'s: BL5-14 Front BL5-11 Rear SLR may have changed THEIR part #'s...but the shocks are still available from eshocks, etc...if needed. ____________________________________ Hope that helps!
#428182 - 20/08/07 10:31 PM
Rancho makes the RSX. I think the part numbers were 17123 and 17124, but I can't remember, as it was several years ago.
Rocky Mountain Suspension should have the Rancho part numbers.
#428183 - 21/08/07 01:22 PM
Loc: iowa
I ended up getting the Bilstein. Damn, they don't give them away so I hope I have no regrets.
#428184 - 22/08/07 04:38 PM
rsx17124/23 are correct for the Ranckos
#428185 - 25/08/07 12:49 PM
Zipster, how do the Bilstein's feel? Did you install them yourself?
Where did you end up buying them, and were they the same part #'s I sent you?
#428186 - 30/08/07 08:42 AM
since we are on this subject, I have a 2005 OFF ROAD that I would like to stiffen the suspension for better feel handling on road and through curves. The body is all OEM. I would love to get the tight feel that my 2006 Rubicon has. Seems to be a little mushy going down the road
