#428410 - 21/06/06 02:23 PM Which Bilstein for for a 2" PML?
confused
Bilstein
5100 Series
5100 Series - Preload Adjustable (0-2" Ride Height Adjustable)
5125 Series
#428411 - 21/06/06 03:06 PM Re: Which Bilstein for for a 2" PML?
search
#428412 - 21/06/06 07:05 PM Re: Which Bilstein for for a 2" PML?
#428413 - 21/06/06 10:29 PM Re: Which Bilstein for for a 2" PML?
If you're going to do some off roading, get the extended ones for use with lift kits from Spencer Low Racing. The OEM versions will work, but the extended ones will give you more droop/articulation off road. If you have question about them, call SLR and talk to Josh. Good Luck.
#428414 - 21/06/06 10:52 PM Re: Which Bilstein for for a 2" PML?
thank you!
#428415 - 22/06/06 02:17 AM Re: Which Bilstein for for a 2" PML?
The ones I listed are extended atleast for the 4x4.
#428416 - 22/06/06 04:11 AM Re: Which Bilstein for for a 2" PML?
Don't do a 2" PML.
Its too high for the UCA's to adjust for.
Keep it to 1.5".
Also, there's no really good ways to get the rear up 2".
The 2" SLR shackles are actually shorter than the Calmini 1.5" lift shackles (As bizarre as that might seem, I think they mean that they're ~ 2" LONGER than stock, rather than that they LIFT you 2")...and the AAL for a PML defeats the purpose due to the less P part....and, the fact that an AAL-only lift kills your articulation, whereas a shackle lift INCREASES articulation.
And the Bils for the 3" lift work at stock or PML height too...so you can later upgrade to a taller suspension, etc...w/o having to get shocks again.
#428417 - 22/06/06 11:46 AM Re: Which Bilstein for for a 2" PML?
[QUOTE]Originally posted by TJ:
[QB]Don't do a 2" PML.
Keep it to 1.5".
TJ thank you for your response. What do you think about this?
http://www.4x4parts.com/public_html/shop...7a2d64815e710d4
It seams like has the Bilstein shocks and 3" lift total?
#428418 - 22/06/06 12:26 PM Re: Which Bilstein for for a 2" PML?
Well, I think its a 3" lift kit.
Its a good kit from what I've heard, at least I don't know anyone complaining about it.
It comes with new UCA's...so that you CAN get alignment.
#428419 - 22/06/06 12:29 PM Re: Which Bilstein for for a 2" PML?
Thank you!
