The shackles give 1.5" rear lift, the T bar crank gives 1.25 - 1.5", and, the X was slightly nose down from the factory to compensate for rear cargo loading, etc...
So if you are looking at it and its a little nose down, it started that way...even if you raise the front and back 3", the front will still be nose down.
The answers above are good btw
Is the ride bouncier?
You might want to back off the bumpstops to a 3/4" clearance if it is.
