#428943 - 26/04/04 04:56 PM I knew I shouldnt of gone to moab
Well I'm about to bite the bullet and order a calmini lift kit. I'm fairly sure at this point I am going to order it with out the shocks which saves $100 and go with the bilstiens.
The install for the most part looks strait forward to me but I do have some questions about the ball joints as I have never messed with them before. I understand I will need to pick up a pickle fork to get it apart along with a bfh. Are there any other tools that are needed for that portion beyond normal hand tools. Any hints or tips would be appreciated.
#428944 - 26/04/04 05:31 PM Re: I knew I shouldnt of gone to moab
Saline Offline
Loc: Fruita , CO
Thats about it. Many, including myself had a %$@%# of a time getting one or both ball joints off.
Also somehow the rear diff slid forward when doing the AAL. I tried and tried and couldn't get the housing to seat on the pin. Finally I used a ratchet strap around the receiver hitch and back to the housing to pull it back into position.
Desert Solitaire
#428945 - 26/04/04 05:32 PM Re: I knew I shouldnt of gone to moab
I've heard a lot of guys using a pickle fork, but I never have. I don't even own one. And I do a lot of suspension work (rack and pinions, ball joints, center links, etc.).
Just hit it really hard. Swing like it's your ex-wife. HARD!
Hit the part that the ball joint goes into, not the joint itself. You'd be surprised how easy it is once you do it a couple of time. Just don't hit the threads, that sucks.
A measuring tape, a couple of 19mm wrenches (or a couple of ¾" wrenches, which are the same size as 19mm), 17mm wrench, 22mm wrench (again, a 7/8" wrench is the same), BFH, 14mm wrench (sorry, it's a 14mm), 12mm wrench, perhaps a 10mm wrench, anti-sieze (lube 'em up!), jack, jack stands (don't get under the vehicle with just a jack holding it up, or I'll come over there...), common sense, beer and pizza.
Did I forget anything?
#428946 - 26/04/04 05:54 PM Re: I knew I shouldnt of gone to moab
Cyclemut, I've tried that and I've never been able to find a good angle to get a good swing. If it's up on a lift, and you can swing the BFH from underneath I'm sure it's a lot easier.
I've done 6 installs now at my house, and we have the balljoint thing down pat. Just compress the suspension with a floor jack, tap the pickle fork in, then drop the suspension, it pops right out.
#428947 - 26/04/04 05:59 PM Re: I knew I shouldnt of gone to moab
Do you end up tearing the boot with the pickle fork? I've always been warry of that.
But very true about the lift, I'm spoiled. When my butt hits a garage floor to do anything on a car (no lift) then I kind of go into shock. I need beer to revive me.
#428948 - 26/04/04 08:03 PM Re: I knew I shouldnt of gone to moab
Ian, remember we learned NOT to loosen the torsion bars with that method.
Yes, very messy
#428949 - 26/04/04 08:05 PM Re: I knew I shouldnt of gone to moab
I thought the new kits came with Bilstiens??
#428950 - 26/04/04 08:39 PM Re: I knew I shouldnt of gone to moab
Not sure if they do now or not. Going to confirm it in the morning when I order the lift. There's no mention on the website that they are now shipping with the bilstiens.
Just out of curiosity does anyone know how much a used set of bilstiens sell for as I'm going to have a set to sell here shortly with 15k miles on them
#428951 - 26/04/04 09:29 PM Re: I knew I shouldnt of gone to moab
We cut the boot away prior, otherwise it absorbs the blow from the pickle fork.
I spaced out the last install and we did loosen the torsion bars somewhat to allow the suspension to compress better. We had to tighten them up to get the ball joint to pop out.
#428952 - 26/04/04 10:38 PM Re: I knew I shouldnt of gone to moab
Aero Steve Offline
Air tools make life easier, otherwise get something to use as a breaker bar. Bolts exposed to salted roads can be a bitch. I use my hi-lift handle slipped over the handle of my 1/2 rachet. I don't know if Calmini includes new U-bolts for the rear leaf springs, get some if they don't and remember to check the torque after a few hundred miles.
When I did my lift kit I got a set of assorted pickle forks. The smallest size I had, labeled a tie-rod fork, was the easiest for me to pop apart the ball joints. Since then I heard of the method of tapping the knuckle with a BFH where the taper is. It's worked well for replacing ball joints, but like Ian said getting a good swing on it with the stock arm may be tricky.
#428953 - 27/04/04 06:11 AM Re: I knew I shouldnt of gone to moab
I'm going to be installing mine as well as soon as it gets here..I'm also installing the SS,now what I've heard is that I should look into getting an extra set of Cam bolts cause of them being a bitch..Is this true??
#428954 - 27/04/04 06:59 AM Re: I knew I shouldnt of gone to moab
Aero Steve Offline
The cam bolts shouldn't be too bad if you have been getting alignments every so often. I replaced mine because they were chewed up from frequent alignments.
#428955 - 27/04/04 11:43 AM Re: I knew I shouldnt of gone to moab
Lift is ordered. Right now its not available with the bilstiens. Shipping was 68 dollars. It looks like mid may I'll be out in the garage. Maybe it will actually be in the 50's by then.
Speaking of air tools are there any brands that would be recommended that are affordable. Been on the list for a while and I do already have a compressor.
#428956 - 27/04/04 12:41 PM Re: I knew I shouldnt of gone to moab
Aero Steve Offline
I've just got a bunch of campbell hausfeld stuff I bought a walmart. I've had them for my impact wrench and air rachet for ten years and they've held up.
#428957 - 27/04/04 05:22 PM Re: I knew I shouldnt of gone to moab
Hustler Offline
Loc: ogden,ut
When it comes to tools, cheap is not a good thing.
"I'm older now but still running against the wind" Bob Seger...
#428958 - 27/04/04 08:34 PM Re: I knew I shouldnt of gone to moab
I'll second that, but for the average Joe, buying a solid Ingersol Rand Impact gun, or a Snap-On 3/8" gun would be overkill.
#428959 - 27/04/04 08:42 PM Re: I knew I shouldnt of gone to moab
Aero Steve Offline
Normally I'd agree, and if I needed them on a daily basis I'd buy better quality. But for occasional use they aren't bad.
#428960 - 28/04/04 09:33 AM Re: I knew I shouldnt of gone to moab
KCX Offline
Loc: Kansas
Hopefully your kit has the new UCA bushings that Calmini is sending out now to replace the old white bushings. I called last week to complain about the squeak sounds and they shipped me a whole new set in less than 3 days. Very impressed with Calmini's business with customers.
Get the Calmini Steering Sytem too! You'll need it sooner then later.
www.hxoc.net
#428961 - 28/04/04 10:31 AM Re: I knew I shouldnt of gone to moab
Aero Steve Offline
They have been shipping the black bushings for almost a year. I replaced mine late last summer with them.
#428962 - 28/04/04 10:50 AM Re: I knew I shouldnt of gone to moab
surfingteacher Offline
Loc: Richardson
I got black bushings with mine about a month ago.
Scott, you might want to see about getting some of the new black bushings.
TNT #14
SWXC #95
I wish I could think of something clever to put here.
Cardomain
#428963 - 29/04/04 06:12 AM Re: I knew I shouldnt of gone to moab
I got half of my order in yesterday....I got the shackles and UCA's...The t-bars and sterring system is on backorder... :rolleyes:
#428964 - 29/04/04 07:16 AM Re: I knew I shouldnt of gone to moab
Aero Steve Offline
You got my shakles laugh I ordered some stuff from xterraparts and when everything showed up I had no shackles. Did you order from xterraparts or Calmini? If you did it straight from Calmini, you can call and pester them about status for your parts. XterraParts won't know anything. I wouldn't do it more than once a month or whenever they say you should have them. Hopefully it won't take that long for them to produce some more.
In the mean time you could go ahead and lift it with what you have. The T-bars and steering are used to fix problems you will have down the road. Like sagging T-bars and worn out steering. I did 6 months on my original steering before it was shot and it's only been in the last couple months my SLR T-bars quit sagging that I installed 2 years ago.
#428965 - 29/04/04 08:26 AM Re: I knew I shouldnt of gone to moab
When I ordered mine earlier this week calmini claimed the T bars were backordered and at the time were being powder coated. I was told it would be a 7 day delay.
Hopefully by late June mid July I will be order the steering system.
#428966 - 29/04/04 02:12 PM Re: I knew I shouldnt of gone to moab
[b]I got half of my order in yesterday....I got the shackles and UCA's...The t-bars and sterring system is on backorder... :rolleyes:
In the mean time you could go ahead and lift it with what you have. The T-bars and steering are used to fix problems you will have down the road. Like sagging T-bars and worn out steering. I did 6 months on my original steering before it was shot and it's only been in the last couple months my SLR T-bars quit sagging that I installed 2 years ago.[/b]
I got mine through Xterraparts,so if you ordered it thru them then I did get your shackles... wink
Yeah I could install the stuff now but I figured I'd wait until I get it all so I don't have to keep making trips to the alignment shop...
#428967 - 29/04/04 02:20 PM Re: I knew I shouldnt of gone to moab
Aero Steve Offline
My shackles showed up today smile For an alignment you should look into Firestone's lifetime alignment. Take it in whenever you want and it's no additional charge. It's around $100 up front, but I've had 6 alignements on it and know I'll have more in the future.
