If you have aftermarket UCA and if you are the one who bolted the control arms and ball joints,
make sure to check those bolts periodically.Yesterday, I was preparing to replace my worn out centerlink. I took off my front tires for more space to work on, then, I noticed that the driver side bolts (x4) that connects UCA (Calmini) and hi-angle ball joint were VERY loose. Two of 4 bolts had about 1/4" gap... They were basically about to come apart.
Okay...I've driven about 7K miles since they were installed, so I know I should have checked earlier... I did use locktite - blue (sp?) when I was installing UCA. So, I was taking it for granted; I believed that they were secure. The passenger side had no sign of "coming to loose."
I think that
you have to bolt ball joint and UCA if you purchased them from Calmini or AC?
Just thought to remind about this to those who installed UCA before someone reports an accident on a road....
