#429957 - 03/07/03 08:32 AM Any suggestions for getting the upper A arm bolt
Powerguy38 Offline
Loc: Greensburg, PA
on the left out? On the passenger side, the bolt torwards the rear won't come out. The other one came out without any problem. This one is in there in such a way you really can't get a good hit on it with a hammer.
ECXC 2K12 Organizer
#429958 - 03/07/03 08:56 AM Re: Any suggestions for getting the upper A arm bolt
Olegkha Offline
Loc: Brooklyn, NY
you can get a small torch, and burn the rubber out from the a arm ( but carefully )
or cut the bolt off
#429959 - 03/07/03 09:07 AM Re: Any suggestions for getting the upper A arm bolt
Powerguy38 Offline
Loc: Greensburg, PA
The only torch I have is a propane one. How would it help to burn the rubber bushing away? I've got one stuck one each side now. On the drivers side, the bac bolt came right out. It's the front one that is stuck. mad
ECXC 2K12 Organizer
#429960 - 03/07/03 10:21 AM Re: Any suggestions for getting the upper A arm bolt
Olegkha Offline
Loc: Brooklyn, NY
we just aimed at the bushing, ( between a arm and the bracket that is welded to the frame ) and just let it burn for couple of minutes ( pay attention to stuff around , wires, and brake lines )
then when you smell ruber burning stop the torch, and try to hit the bolt again
then burn some more, then hit, then burn , then hit wink ( it worked on 2 trucks )
#429961 - 03/07/03 12:11 PM Re: Any suggestions for getting the upper A arm bolt
Powerguy38 Offline
Loc: Greensburg, PA
I should have a Sawzall in about 1 1/2 hours so I hoping to just cut the bolts off. laugh
ECXC 2K12 Organizer
#429962 - 03/07/03 02:12 PM Re: Any suggestions for getting the upper A arm bolt
Carlton McMillan Offline
Loc: MN
unless you did something really bad to that bolt it should not be that difficult to remove.
#429963 - 03/07/03 04:23 PM Re: Any suggestions for getting the upper A arm bolt
Ag_xterra Offline
Loc: San Antonio, TX
nissan doesnt use anti seize grease on their bolts like they should. the problem is the bolt rusts to the metal sleeve in the rubber bushing and it then becomes seized together. you can try to apply heat to the sleeve and bushing area, then take a big breaker bar and keep working at it. the best way is to either cut if off with a torch or use a sawzall to cut the bolt off. its a grade 10.9 bolt so make sure you have a few extra blades.
#429964 - 03/07/03 05:03 PM Re: Any suggestions for getting the upper A arm bolt
Powerguy38 Offline
Loc: Greensburg, PA
CM, my X has been through a LOT of mud and water in it's 90,000+ mile life. The bolts were very rusted. Two came out, two didn't. I cut them with a Sawzall. Problem solved.
On a side note, How tight do you tighten those bolts back? I don't remember seeing anything on it.
ECXC 2K12 Organizer
#429965 - 04/07/03 08:26 AM Re: Any suggestions for getting the upper A arm bolt
X2K Offline
Loc: 41.556895 N, 72.665225 W
Did you get the nut off? and you just cant remove the bolt? Try putting a jack under the brake and taking a little pressure off it. It should easily remove.
Dumber then a box of rubbers
Some People are Douche Bags
IFS SUCKS!
http://www.grovestreet.com/jsp/onepic.jsp?id=186476
#429966 - 07/07/03 06:09 AM Re: Any suggestions for getting the upper A arm bolt
Xcited Offline
Loc: Guelph, Ontario, Canada (Eh!)
I had the same problem when I did my UCA's last month, except ALL of my bolts were seized in. I cut the bolts off on the drivers side with a SawzAll, but ran out of blades when I got to the passengers side. Then out came the torch. We cut off the bolt ends enough to be able to "persuade" the stock UCA (with bolts still inside) to come out with a little bending/deflection of the frame brackets.
It was a roral PITA, but in the end it got done! [Too much XOC]
Vice President - Director of Operations: Southern Ontario Xterra Club (SOXC)
Member: Northern Lights - Ontario Federation of 4WD Recreationists (OF4WD)
Member: New England Xterra Club (NEXTerra)
Member: Toronto Area Rover Club (TARC)
Home Page: XterraXcursions
