#430797 - 19/01/02 02:39 PM Articulation Question
Jeffrey Robinson Offline
Loc: Jacksonville Florida
Here is a question I haven't found an answer to in my searches (maybe I'm looking under the wrong thing).
After removing the rear Sway Bar, how much articulation will the rear wheel have? Everything on the truck taht affects the rear wheel articulation is stock.
I'm asking because I need to figure out what size Jack I need to buy to get the rear wheels off the ground.
[ 01-19-2002: Message edited by: Jeffrey Robinson ]
Jeffrey and Rockaholic
Men watch pornos for the same reason that women watch romantic comedies:
We like to see things that will never happen to us.
Displaced member of Nexterra
#430798 - 19/01/02 04:58 PM Re: Articulation Question
superjens Offline
Loc: North Vancouver
Where are you jacking it up from? You can always use the original jack under the spring hangar, works good for me and my sway bar is long gone.
#430799 - 19/01/02 06:34 PM Re: Articulation Question
Exactly, you lift the rear from the bottom of the spring, so there's no suspension travel used. If you lift from the frame like the front end calls for (or hi-lift from the hitch or sliders), then you have to worry about extra droop (except that's what a hi-lift is all about).
#430800 - 19/01/02 11:47 PM Re: Articulation Question
Yeah, I can do that. I may have times whee lifting from the sliders of frame will be a better option, depending on what I am doing or where I am doing it.
Also, it's just nice to know (because I know my friends here will be asking how much art. I have now, which has occurred already shocked )
#430801 - 20/01/02 12:03 AM Re: Articulation Question
Kerensky97 Offline
Loc: Utah
Ian Measured his:
From xterrain.com
-Dustin
Xterra101.com
#430802 - 20/01/02 08:34 AM Re: Articulation Question
Originally posted by Kerensky97/ NOXCAPE:
Ian Measured his:
From xterrain.com
Cool, thank you for the link.
