#430960 - 14/03/05 07:29 AM Rear Suspension Limits
I was moving stuff out back to see how much room I had to stuff an Air Tank under where the spare used to go...so I was flexing the diff/frame up/down to check clearances....
(I have the Calmini AAL/Shackle lift in back, and the ride height/level ground, wheel arch to center of hub distance was 24.5", with a 3" SL/2" BL)
I noticed some interesting things out back...
1. The limit to my droop is my rear spring pack, not my shocks....
2. With the sway bar on, the sway link hits the shock on droop...(Pass side)....stopping down travel at 28" from wheel arch to center of hub.
3. Disco'd, the wheel can drop another 1.5" of droop, before the springs stop it.
4. From wheel arch to center of hub, I got 29.5" max droop (Disco'd) unless I push down on the tire, stretching the spring a bit more...I didn't hit the end of shock travel.
5. At full droop, I had ~ 8" axle to bump stop clearance.
6. Picking up the opp corner to compress the rear, I got to 20.5" arch top to hub center, and about 4" bump stop clearance. (NOT full compression, just a load from opp jacking)
7. At the above compression, the spring pack was not completely flat, but almost...with ~ 4" Bstop travel left.
I am curious if anyone has measured their wheel travel limits?
I am specifically interested in how a AC or SLR AAL or new packed 3" lift would compare.
I used the hub center to top of arch measurement because it eliminates the tire size issue in comparisons....I have 33x12.5's on there for example.
Anyone else measure?
#430961 - 14/03/05 08:25 AM Re: Rear Suspension Limits
If I can get around to it this week, I'll see what I've got for you. I know my droop is a bit more with the Deaver springs. Not sure how much though.
#430962 - 14/03/05 01:18 PM Re: Rear Suspension Limits
Sounds dangerously like a plan!
I figure we have Deavers, SLR's 10 Pack & AAL versions, AOR/Orbit Eyes, Alcan, etc...
So there should be some variation...plus, there may be some people with Calmini lifts who have different results, etc.
Should be interesting to see what works.
#430963 - 14/03/05 02:06 PM Re: Rear Suspension Limits
Hey TJ after al of your advise I decided to keep the SLR AAL pack and order the 1" shackles to complement them, as soon as I get them on I'll take measurements, and take some more after I break things in a bit (and hopefully not just break things!) smile
#430964 - 14/03/05 03:42 PM Re: Rear Suspension Limits
I have the same problem, and it doesn't take much droop to bang the shock. I do have extended length Bils and I think they are a bit bigger around than stock, but even the stocker on that side had some dents in it where it banged into the swaybar. I do have Calmini shackles.
The thing that sucks is that I don't want to damage my shock (it is already missing a bit of paint) so I basically don't use the rear swaybar anymore - but that makes for some quite a bit more understeer than stock while cornering, which really sucks. frown
#430965 - 14/03/05 03:56 PM Re: Rear Suspension Limits
I need the swaybar on there...I drive on highways too much.
I'm looking to adjust the clearance a bit to make some room, and I'm looking to install a QD that will be easy enough to take off that I'll actually do it when off road.
I had a set of JKS Quicker Disco's on my last Jeep, and they never rattled, and were a breeze to get on/off, even on uneven ground.
They are also adjustable for length (~8-11.6" or so...) so I should be able to fab something that reaches the 9.5" or so the X needs from it.
If it works, I'll let everyone know...the other QD's for the X are rattle traps.
Speaking of Calmini Shackles...I wonder what the droop would be with the shackles, but no AAL?
#430966 - 15/03/05 04:32 AM Re: Rear Suspension Limits
Xterradon Offline
Loc: Franklin Park, NJ
Just curious... There doesn't seem to be much curve in your spring pack??? frown Is that because of your shackles?
(Sorry, I wasn't paying attention, I'll shut up)
-Bryan
#430967 - 15/03/05 05:11 AM Re: Rear Suspension Limits
Well in that last pic he has his wheel stuffed.
Tom
#430968 - 15/03/05 06:44 AM Re: Rear Suspension Limits
Tom's right, as captioned, the spring is on the compressed side, and as noted, is almost flat in that position...with about 4" of bumpstop clearance remaining...and about 4" of possible travel of the tire upwards based upon a diameter of 33", and a radius of 16.5"...and 4" of (hub center to arch) travel potentially available.
IE: The tire could theoretically go up another 4" into the well, raising the rear of the spring another 2", at which point, it would be totallly flat....and on the stop.
#430969 - 15/03/05 06:49 AM Re: Rear Suspension Limits
You won't get any more travel w/ an AAL, no matter who's AAL setup it is. You're limited in your travel by the stock springs, regardless. There are only 2 ways to increase it; buy a longer shackle (which you've already done), and buy a complete leafpack replacement.
#430970 - 15/03/05 06:55 AM Re: Rear Suspension Limits
Porche - My assumption was that you are right...and that the only improvement was shackle based on an AAL/Shackle lift..but some AAL/Shackle lifts use 1", 1.5", and 2" lift versions...
I was also wondering if a worn out spring pack that is sagging can droop further than a newer, stiffer one, or if the de-arching is unidirectional as far as metal fatigue, etc.
It will be interesting if we can establish some baseline emperical data.
#430971 - 15/03/05 07:35 AM Re: Rear Suspension Limits
Nope. Because the leaf spring is fixed at one point, and hinged at the other, your down-travel is limited by those two factors, and the overall length of the main leaf. Unless that steel stretches, then that's your absolute, limiting factor... And if it's stretching, well... You've got bigger problems to deal with!!
So, you can only get more travel by installing a longer main leaf, or installing a longer rear shackle, to make the hinge lever longer. Anything else will just help you get the most out of what's available (longer shocks, remove sway bar, etc.).
An AAL can't increase travel, because the main leaf is still connected at both ends. It's still going to be your absolute, limiting factor.
#430972 - 15/03/05 09:22 AM Re: Rear Suspension Limits
Absolutely.
I'm thinking that a longer spring would require a shorter shackle to maintain the same height, unless the hangers are further apart, etc.
I think a shackle will give more travel than a leaf pack, inch of lift for inch of lift.
A softer spring rate, such that the weight of the axle might pull the tire down further than a stiffer rated spring would allow, might improve droop.
Somewhere out there is the best compromise. (Yeah, we all do coil conversions)
#430973 - 15/03/05 09:49 AM Re: Rear Suspension Limits
Absolutely.
That's next year. wink
#430974 - 15/03/05 10:24 AM Re: Rear Suspension Limits
socalpunx Offline
Yesterday when I was having my bumper built (pics forthcoming) we were looking at different ways to get more droop out of the rear.
While we've spent a bit of time (and $$) recently playiing with the rear and esthetics along with the new spring pack, completing the rear end should mark the end of this faze of mods tot he X.
I wish to not go too crazy (too late ) but there are a variety of options.
The only real way for me now to measure full travel cycled would be to seperate the leaf pack and cycle the pack one leaf at a time and do it right. My perfect universe will add more time to my day .
In a perfect universe in which I also have a money tree and an extra vehicle to drive while my truck is being worked on we would get a longer leaf pack ( we are still longer than a Jeepspeed's 54" race pack though. Damn those things are short) and relocate the front perches foreward and then put in reversed extended shackles.
The limiting factor with mine and Ed's springs is the shocks. Looking up underneath, we have about 3-4 inches up under the body to work with. My goal (pre cage) is to still have the truck as functional and family friendly as it was when it was new. So staying under the bed is key.
A "cage" of gusseted tubes seems really feasable. There's plenty of room to stay under the "bed." All we have to do is relocated the lines that run on the pass side that go to somesortofemissions/fuellcanfilterlookingthingy? that is tucked up in there.
We'll measure up and fined a 7100 or so that should work and we're going to get fabbed a reverse lower driver's side shock mount so that both shocks are on the same plane.
#430975 - 15/03/05 01:35 PM Re: Rear Suspension Limits
Hmmm.
SAS, Coil Overs all around, as long as I never eat or buy anything for a couple of years....
It COULD happen.
#430976 - 15/03/05 01:57 PM Re: Rear Suspension Limits
socalpunx Offline
The only way to get CO's in the rear is to link it. I've seen a few Explorers that have been linked but it is a massive ammount of work to get it done back there as opposed to doing a well thought out leaf set up.
#430977 - 15/03/05 05:12 PM Re: Rear Suspension Limits
OnlyOneDR Offline
Just buy Revolvers and be done with it. Your shocks will then be the limiting factor (unless you put in limiting straps).
I am running custom Alcans, Revolvers, and RS5112 rear shocks. The shocks limit the travel. I have been planning on increasing the size of my bumpstops so I can run a longer shock without bottoming out, just have not gotten there yet. Right now with this combo I have to run a 3/4" spacer under my bumpstop to keep from bottoming the Ranchos.
http://www.noas4x4club.com/
#430978 - 16/03/05 05:04 AM Re: Rear Suspension Limits
Did the revolvers bolt right in, or was there fab work involved?
They had a X specific application at one point, but they don't now...is there an off the shelf version that fits?
#430979 - 16/03/05 06:45 AM Re: Rear Suspension Limits
Awe, crap. Just realized the X and the Frontier are different; nevermind...
If you were SOA, like the 4x4 Frontier, then you could use revolvers from a Cherokee; same spring width and hanger bracket width. But since your not, that won't work.
AC used to carry the revolvers for the X and Frontier. Do they not anymore? They're still posted on their website, anyways.
#430980 - 06/06/05 12:51 PM Re: Rear Suspension Limits
I was working on the X this weekend and remembered this thread so I took some measurements for you TJ. Of course I goobered the whole thing and measure differently than you did so it's a moot point. I'll crank it back up tonight and see what I can get for you.
#430981 - 06/06/05 04:04 PM Re: Rear Suspension Limits
Goobers, raisinettes, its all good.
#430982 - 12/06/05 11:52 AM Re: Rear Suspension Limits
EditorX - So - What's the story?
#430983 - 12/06/05 06:32 PM Re: Rear Suspension Limits
Quick math job on this one. I took my last totals that were from the top of the tire to wheel arch and then added the difference to get the total from arch to the center of the hub. Anyway, full droop by oposite jacking gives me 30 inches of droop center to arch. I will have to measure forced articulation next time I am out. I had a good one today but didn't have a tape handy.
Edited for beer induced typo. BTW TJ...I am running 33's like you, but without the BL. I just have the Deaver spring pack and 6 inch shackles.
#430984 - 13/06/05 08:10 PM Re: Rear Suspension Limits
OK - Emperical data!
If I have 29.5" of droop from the well arch to hub center...and you have 30" for the same measurement...and My 2" BL makes my well arch 2" taller w/o added travel...you gained about 2.5" of droop up and above the AAL/shackle set up.
Now...to add a new variable...I have a set of revolvers I'm looking to pop on....collapsed they're about 1/2" less than the 3" lift shackle on there now...but open, they should get quite a bit longer.
In a few weeks...I should have some new measurements.
Collapsed shackle length's about the same as the 3" lift shackle eye to eye.
I still need to measure the extended eye to eye distance...the extra droop would be about half that distance.
Extended Measurement.
