I wrote to them yesterday to get some more info and this is what they wrote back.
The system features all of the following parts and innovations. The rear crossmember allows for removal of the front differential without the need to unbolt the entire subframe. The base system without shocks will be around $2,600.00. With our recommended KING shock in front and Bilstein in the rear, the price will be around $3,699.00. The system will provide for 5” of lift and will clear a 33.5 with no need for trimming. It may possibly clear a 35”, but we have not perfected the trimming. The Bilstein front shock option is not yet available, but will be in the coming weeks. The kits should begin shipping by the end of the month. Check out the products page of our website for pictures of the system mounted onto a Frontier. The Xterra system will be exactly the same, the only difference being in the rear spring pack add-a-leaf system. The subframe is the same, along with the 2.5” remote reservoir shock in the front. Feel free to call the shop at 951-688-2025 if you would like to discuss this system further. We are currently taking $1,000.00 deposits for the first set of subframes arriving next week, 8 are already sold. I look forward to thearing from you soon.
Joshua @SLR
· CAD designed suspension and bracketry
· Constructed from Lasercut ¼” A36 Plate
· CNC machined steering clevis
· CNC machined spindle
· 4130 Heat Treated Tie Rods
· SLR designed billet UCA’s with uniballs
· SLR 3 piece rear crossmember to brace differential
o Ties in rear LCA drop down pivots and crossmember
· SLR Deaver Add-a-Leaf System
· SLR 1” or 2” Shackles
· Multiple Shock Packages
o Package 1: Front Bilstein Coilover, Rear Bilstein shock
o Package 2: Front King 2.5 Coilover w/ remote reservoir, Bilstein Rear Shocks
o Package 3: Front King 2.5 Coilover w/ remote reservoir, Rear King 2.5” shock
· Other options:
o King 2.5 Hydraulic Bumpstop: acts not only as secondary suspension, but also as an adjustable sway system
o Deaver Full Replacement Pack: benefiting from a computer aided design, this is the ideal way to improve performance over the OEM set-up
