#434244 - 07/09/03 07:57 PM Calmini steering ball joint problem
Bowski Offline
Loc: Great Lakes, IL
I have the calmini ss on my x. I feel a clunk when turning at low speeds. While taking a look under the front end today i noticed that both the ball joints on the calmini center link had grease coming out of them. I tightned these things down correctly when I put it on. I notice that they have a zerk. Is this common for them to do that and should i just put more grease in them? If they are bad, then i'm pretty sure that they are causing my steering clunk. Whats the part number if they are bad, so i can replace them. thanks
BLUE!!! You're my boy BLUE!!!
-Frank the Tank
#434245 - 07/09/03 08:31 PM Re: Calmini steering ball joint problem
ChuckH Offline
Yes, the grease will come out and you need to put some in once in awhile since they aren't really sealed. I do mine about once a month. More than likely your clunking is coming from the idler arm though. As the finish wears it needs to be tightened. I'm not sure what the torque should be, but I tightened mine once because it was noticeably loose. After a year and nearly 30K miles I have yet to experience a problem with my steering system.
#434246 - 07/09/03 09:17 PM Re: Calmini steering ball joint problem
Bowski Offline
cool! I saw the zerk and was hoping that was the case. I'll check the idler arm again. I've got the non powedercoated version so hopefully its just a little loose. We'll see what happens. Thanks
-Frank the Tank
#434247 - 07/09/03 09:22 PM Re: Calmini steering ball joint problem
ChuckH Offline
Yeah, I have the very last powdercoated system Calmini shipped. I would think that even the nickel plated ones would have some wear and give though so it's worth checking.
