#435241 - 25/08/04 06:16 PM Bill Stein?
Are the Bilstien 20% stff shocks "the" choice for the 01'X/?
#435242 - 25/08/04 06:54 PM Re: Bill Stein?
I sure do like mine, on a '04 XE 5 spd!
#435243 - 25/08/04 09:08 PM Re: Bill Stein?
They made my X pretty "jittery" on small irregularities on the road, but they soak up the larger/longer stuff very well, especially when loaded down. If you're not going to work 'em hard, go with something softer.
#435244 - 27/08/04 07:29 PM Re: Bill Stein?
I just recently put a set of Bilstein's on my X with 20% stiffer up front and OEM valving in back to compensae for when I get my ARB on....But if your not planning on wheeling your X alot or if your not planning on throwing on the extra weight of and ARB then I'd have to aggre with Brent and say get the regular Bilstein's instead...
#435245 - 27/08/04 09:59 PM Re: Bill Stein?
Thanks Gang! good info! Not a full time 4 wheeler as such...just in to being able & prepaired..then I'm going to assume that the reg Bilstien's are superior to stock?
thanX!
#435246 - 28/08/04 05:48 AM Re: Bill Stein?
thanX!
Deffinetly better than stockers...
#435247 - 29/08/04 11:02 PM Re: Bill Stein?
Most of the backroads around here are gravel, and by this time of year they're full of washboards. I've gotta say, the stiffer Bilsteins do make it a bitch to drive over - but then, its not a very pleasant surface to traverse to begin with.
#435248 - 30/08/04 07:47 AM Re: Bill Stein?
I have the Bils 20% stiffer in front and the "Heavy Duty" (stiffer) in back. I did this because I knew I would have steel all around, and the tire carrier adds alot of wheight to the rear.
The ride when the truck is empty is fine. At hight speeds I do notice the "bumpy" feel as you can feel everything on the road.
All around: I am happy with them!
#435249 - 30/08/04 10:00 AM Re: Bill Stein?
It seems like my X is getting heavier by the week so I love my Bils.
