131
3
#443094 - 30/01/07 12:43 PM
Re: ATA Hard Drive Mystery...Need Help
What sizes are the drives?
#443098 - 30/01/07 05:36 PM
If you use an External enclosure YOU MUST set the drive as a Master - Regardless of your Internal drive settings. Those are basically ignored when you use the drive via USB. If you have it set to Slave then that is your problem for sure.
I think there is an adaptor that converts the SATA connection on your MB to IDE, might be worth trying it internally like that if you continue having a problem externally.
Another thing you might want to try is check your 'Device Manager' for any problems. Right Click 'My Computer' then go to the Hardware Tab, then 'Device Manager'. Anything that is conflicting should be clearly visible.
#443100 - 30/01/07 08:23 PM
Loc: My Mama, originally
Get to your Control Panel, open Administrative tools, then Computer Management, then Disk Management. Look to see if the drive shows up there, but doesn't have a drive letter assigned. If so, just give it a letter and it should show up fine. I've seen this happen a few times. Worth a shot.
Also, for some odd reason, sometimes you can type the drive letter, i.e. E: in the run box, and it'll open up, even if it's not showing in My Computer.
Who knows, who cares... let's go.
#443101 - 01/02/07 08:30 AM
Loc: Yorktown, VA USA
Originally posted by Auditor: Get to your Control Panel, open Administrative tools, then Computer Management, then Disk Management. Look to see if the drive shows up there, but doesn't have a drive letter assigned. If so, just give it a letter and it should show up fine. I've seen this happen a few times. Worth a shot.
Also, for some odd reason, sometimes you can type the drive letter, i.e. E: in the run box, and it'll open up, even if it's not showing in My Computer. What we get here alot with jumpdrives is that it will assign the drive a letter that has already been assigned. Strange, I know, but Windows only seems to like to give out A: - G: Check to see what letter it is assigned in the disk manager as described by auditor. If you change the letter on the external drive in question to something not in use, it should pop right up. You should be able to use any letter through z: that isn't being used already.
jerseydevi1 "I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. " -Thomas Jefferson
#443102 - 01/02/07 10:20 AM
Why not just hook up the 120GB as an internal drive on an ATA connection? Most motherboards have connections for both SATA and ATA drives. I have yet to see one that's strictly SATA. When you do it, just make sure youre not setting that one up as your boot drive in the BIOS. If that doesn't work, try this....Go to www.techsupportforums.com and post your question in the "Hard Drive" forums. I'll warn you though...when people reply with ways to fix the problem, follow the steps EXACTLY as they are written. Don't try to take any shortcuts.
#443105 - 07/02/07 11:45 AM
Originally posted by BlueSky: Nothing worked. So next question, has anyone here used one of the data recovery services online? Any recommendations?
Thanks... "Recover My Files" works mint
#443107 - 07/02/07 07:19 PM
Originally posted by BlueSky: I appreciate the suggestion, but software won't work since the computer will not recognize the drive. I think there's physical damage. My bad! Data retrieval from a damaged drive can be very $
#443109 - 09/02/07 11:27 AM
Loc: Georgia
Originally posted by NY Madman: I'm not 100% sure of your situation but....
Have you tried putting the old drives back in their orginal computer - then plugging that computer into your home router or hub and just copying the files over to your new computer? The old computer is dead and gone. It wouldn't boot up and since it was 5 years old, totally obsolete and no longer upgradeable, and I'd spent enough time trying to figure out what was wrong with it, I shipped it back to Dell for recycling. Thanks for the suggestion though. I ended up having much of the data on backups though restoring it was pretty tedious and I did lose some stuff I needed. Since I'm SOL anyway I may try freezing the drive and if that doesn't work, I may open it up and see if there's anything obvious. Always wondered what they look like inside, and I've read one account on the web where a guy claims to have fixed his by opening it up.
#443110 - 09/02/07 12:03 PM
Originally posted by BlueSky: Originally posted by NY Madman: [b]I'm not 100% sure of your situation but....
Since I'm SOL anyway I may try freezing the drive and if that doesn't work, I may open it up and see if there's anything obvious. Always wondered what they look like inside, and I've read one account on the web where a guy claims to have fixed his by opening it up.[/b]If you open the drive you will never see anything that was on it again... These drives are only opened up in high end clean rooms during assembly Even if you put it back together the same way it will most likely not work again
#443113 - 10/02/07 11:42 AM
Loc: Georgia
Originally posted by NY Madman: I wouldn't give up just yet. Not if you need the files.
Ask some of your friends or family members and see if they have a computer a few years old sitting around their closet that you can borrow for a day or so.
Swap hard drives and try to boot it up. Is it going to matter if this drive was a slave originally? It wouldn't have boot files on it, right? I have a Dell bought surplus from work that's in perfect order but runs Windows NT. Would that one be suitable?
#443115 - 14/02/07 09:02 AM
Loc: NoVA
Originally posted by BlueSky: Update...read online about freezing the drive and figured I had nothing to lose. Damn if I didn't get it working for about 5 minutes. Sadly, that wasn't enough time to transfer the files I needed. I'm going to try again today. You can always run the drive from the freezer, or if you are really desperate to get some extended run time: http://www.hardforum.com/showthread.php?p=1028112728
#443116 - 19/02/07 03:36 AM
Loc: Georgia
It's dead. Haven't opened it up but after reading up on that I see why others have said it'll never work again after being opened. So...sayonara to the stuff I didn't have backed up, which turned out to be a couple of folders full of pics and a bunch of music. Some of the songs are on CDs I can reload so all in all, a loss that sucks but can be lived with. Fortunately, with my new computer and Adobe Lightroom, my pics are downloaded to both the primary folder and an external drive backup as they come off the card. My computer is a mirror RAID setup and I'll also be putting my data on DVD's from time to time. Those will be kept off-site in case the house burns down. If I lose anything with that setup, I just wasn't meant to have it.
#443117 - 19/02/07 07:36 AM
Loc: NoVA
Oh yeah, speaking of backing up - probably the coolest, most original thing to ever come from Microsoft - Windows Home Server The thing I like the most about it? You can add hard drives as you need them, and it does all the work of distributing the data and protecting it across multiple drives. Cool stuff! I'm hoping to get invited to beta test it...
