#44347 - 12/04/02 07:56 AM gears?
lew Offline
Loc: sc
does anyone happen to know what size gear is in the rear end of a 2002 xe 4x4 auto? id appreciate any input
#44348 - 12/04/02 10:06 AM Re: gears?
DGX Factor Offline
Loc: Denver, CO
Click on the INFO section and there is some stuff for you to look at.
#44349 - 12/04/02 03:49 PM Re: gears?
lew Offline
Loc: sc
i found nothing in the info section that could answer my question but i appreciate the help
#44350 - 12/04/02 03:53 PM Re: gears?
Look closer.
Tire and Gear Calculators.
4.636, 4.363 or 4.375 depending on what you own.
#44351 - 12/04/02 05:02 PM Re: gears?
lew Offline
Loc: sc
ok i see it. but i would have never thought the X was geared so low. my boss has 4.11 gears in his rear end in a built 67 camaro and it picks the front tires off the ground. well maybe it was done to make the X feel as if it has some power. i know it is low in horses but it feels pretty strong out of the hole for a fairly heavy suv. and it does rev pretty high above 60 mph. thanks for the help guys.
#44352 - 12/04/02 05:15 PM Re: gears?
DGX Factor Offline
Loc: Denver, CO
The statement you just made should make you believe it better. Put the 4.11 gearing in and see if you can even go 60mph while towing.
#44353 - 12/04/02 05:50 PM Re: gears?
DaveDatsun Offline
Loc: Sahuarita, AZ
While the gear ratios may be the same, the larger diameter tires on the X make a big difference vs. the tires on the Camaro. The X tire travels further for every revolution.
dave and xtoy - the 'effective' gear ratio
#44354 - 13/04/02 10:10 AM Re: gears?
2001frontier Offline
Loc: Fort Worth, TX
You also have to consider the transmission gearing. That has a lot to do with why our trucks have such tall gears.
