I won't be going to GOX (even though I'd love to), too far of a haul for the wife and 2 1/2 yr. As for your questions, #2 is IN the intake, not outside, and both the intakes from the stock airbox take air from the inner fender. I conducted another temp test after dinner (wife thinks I'm nuts
). The TC sites were:
#1 New air temp sensor location
#2 Stock air temp sensor location
#3 Intake after air filter/before intake manifold
Fully warmed up I headed for the closest highway. With an outside air temp of 67 degrees, and traveling at a steady 55 mph (2100 rpms), the results were:
#1 68 degrees
#2 68 degrees
#3 74 degrees
Then when I got home (with dirty looks from the wife, and guess who's not getting any tonight :rolleyes: ), I let it idle for 10 minutes and the temp results were:
#1 115 degrees
#2 126 degrees
#3 120 degrees
And all sites were STILL climbing slowly. All I can say is I'll never get one of those cone filters systems installed in the engine compartment, too much heat soak. I still can't believe how much heat gets into the inner fender well (even after I taped over most of the holes). The good news is as long as your moving, and your intake doesn't take in air from the engine compartment, your air intake temperature after the stock airbox is only about 6 degrees warmer than the outside air.
