#453685 - 11/05/06 10:00 PM Replacing fuel filter?
I have a 05 Xterra SE 4X4 and it shows in the manual that the fuel filter has to be changed. I can't seem to find it, anyone help?
#453686 - 12/05/06 03:45 AM Re: Replacing fuel filter?
NSANY Offline
Loc: Scenic NJ
The filter is part of the fuel pump assembly. Haven't done it yet, but the shop manual seems to call for dropping the tank to get to it. I'm hoping there's an access hatch to get to the pump assembly that doesn't necessitate dropping the tank, but I haven't looked.
2005 Nissan Xterra Off-Road / 6MT / KH3
Wondering what NSANY means???
#453687 - 12/05/06 05:36 AM Re: Replacing fuel filter?
I don't think there's an access hatch unfortunately. The manual does call for disconnecting the straps and lowering the tank. PITA!
Here's a general overview of all the parts involved: Linky.
Unless I get some crap in my tank, I'm not going to worry about swapping out the filter.
#453688 - 12/05/06 06:18 AM Re: Replacing fuel filter?
The filter shouldn't need attention for a couple or three more years yet.
#453689 - 12/05/06 07:40 AM Re: Replacing fuel filter?
my jeep is going on 8 years without any in tank work. if you pull the fuel pump assy, you have to replace the whole shebang as a unit, I'm sure.
I guess they figured nobody replaced their fuel filters when they were external anyhow. typically, I'd see anywhere from 10-15 years before cars would stop running due to plugging on f.i. when I used to be a mechanic.
#453690 - 12/05/06 08:20 AM Re: Replacing fuel filter?
I replaced the fuel filter at about 60k miles on my 1st gen X. That was a PITA, but it was external at least. Didn't realize the 2nd Gen was even worse.
#453691 - 12/05/06 02:30 PM Re: Replacing fuel filter?
According to the Nissan Service and Maintenance Guide (2006) page 9, the Fuel Filter is a "maintenance-free item". Unless your filter is clogged or failed in some other way it should not need replacing. You should have received a copy of the Service and Maintenance Guide with your vehicle.
#453692 - 13/05/06 10:07 PM Re: Replacing fuel filter?
Correct. the so-called filter is just a sort of mesh bag that attaches to the fuel pump. It is the same as in my Z - that I have taken apart during my APS TT install.
#453693 - 31/12/07 11:07 AM Re: Replacing fuel filter?
dezurtrat Offline
Loc: Tucson, AZ
So, is anyone doing anything extra to maintain a clean system being that the filter can't be changed regularly such as BG service or just adding fuel system cleaner to the tank more frequently?
I got in the habit of never letting the tank go below 1/4 with my '02 so I'm definitely sticking to that with my '08!
