#455200 - 07/02/07 12:50 PM Replacing 3156 & 3157 bulbs with LED's
I was seriously thinking of replacing the brake & turn signal light bulbs, 3156 & 3157 with their respective 3156LED & 3157LED due to their increased brightness and longer life. Anyone tried this on their 2005 - 2007 Xterra's .
Thanks for any info in advance.
#455201 - 07/02/07 01:58 PM Re: Replacing 3156 & 3157 bulbs with LED's
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=007&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=170076288430&rd=1,1
i found these and was planning to put them in next week. they're replacements for the amber bulbs between the headlights. got a link for the LED ones?
#455202 - 07/02/07 02:10 PM Re: Replacing 3156 & 3157 bulbs with LED's
I replaced mine with PIAA Xtreme whites, they're sweeet.
#455203 - 07/02/07 03:17 PM Re: Replacing 3156 & 3157 bulbs with LED's
just checked them out and i guess those are the ones i'll go with. any idea how 3156 and 3157 are different?
#455204 - 07/02/07 08:23 PM Re: Replacing 3156 & 3157 bulbs with LED's
Just a note, you can replace the brake lights with the LED light, but you have to add a resistor to the turn signal lights or they with flash very very quickly.
#455205 - 07/02/07 08:41 PM Re: Replacing 3156 & 3157 bulbs with LED's
These bulbs can be usually found at Wallymart. I
picked up 3 pairs a few months ago. They were
around $3 per pair I believe.
Wallymart also carries the 194 bulb of this kind as
well-- ones for the license plate size. You should
check there before paying double on ebay.
As far as 3156 and 3157, I don't think it matters
much. I'm using 3156 (X comes with 3157?), and
they work fine. Could be wrong but I believe the
numbers have something to do with the brightness
of the bulb??
#455206 - 08/02/07 12:41 AM Re: Replacing 3156 & 3157 bulbs with LED's
I've changed my rear signals to LEDs. I also installed two 6-OHM 50-Watt resistors for each signal to prevent the rapid flashing.
#455207 - 07/02/08 07:19 AM Re: Replacing 3156 & 3157 bulbs with LED's
as far as replacing the amber bulbs inside the headlights with LED's, i've tried 2 different brands with no luck. LED's seem to only have one mode and work fine as turn signals. the original 3157's have 2 coils though: one for the parking mode and the bright one for turn signals. anyway, the both LED replacements i've attempted to install have burnt out my 10A Illumination fuse, so after putting the originals back in i got nothing in parking mode.
has anyone figured this out? is there a brand of LED's that can handle the dimmed mode?
#455208 - 08/02/08 11:38 AM Re: Replacing 3156 & 3157 bulbs with LED's
XPLORx4 Offline
Loc: San Jose, CA
3156 bulbs have only one filament (2 wires), while 3157 have two filaments (4 wires). 3156 are typically marker lamps or turn signals, while 3157's are for combo tail/brake light (or marker/turn signal, as on the Xterra) applications.
Try the 3157's from Superbrightleds.com
4x4 in uppercase is $X$!!!
#455209 - 10/02/08 06:38 PM Re: Replacing 3156 & 3157 bulbs with LED's
looks just like what i needed. thank you!
