#459410 - 18/01/06 09:41 PM bigger tires
ok i realize that i can fit a 285/75/16 tire on my car with minor trimming. whats the biggest tire i can fit with a 2.5 inch suspenshion lift, 4x4parts.com. and can i fit any bigger tires on the stock rims. by bigger i mean taller and wider
#459411 - 18/01/06 09:49 PM Re: bigger tires
like say a 315/75/16
#459412 - 18/01/06 11:05 PM Re: bigger tires
Even with a 2.5" lift you are not going to fit 35x12.5" tires under there. You might with the 2.5" SL and the 3" BL, but even then I would be supprised because of the width of tire.
Try it and let us know how it turns out:)
#459413 - 18/01/06 11:24 PM Re: bigger tires
great so now i am the guinea pig. how much wider could the 315/75 be than a 285/75, isnt it the same width. or does width increase because of the height but even then its like 2 or so inches bigger, or maybe im just retarted.
#459414 - 18/01/06 11:25 PM Re: bigger tires
or isnt it onlt 1.3 inches wider would i really need a 3inch bl
#459415 - 19/01/06 05:34 AM Re: bigger tires
305's might do the trick. I know that is what TJ suggested I run when the time comes to replace the Rugged Trails.
TJ, comments?
#459416 - 19/01/06 07:21 AM Re: bigger tires
The problem is, only a few people have the lifts right now and I don't think any of them have tried to put 35's on it. I am almost sure they would not fit with just a 2.5" SL. they migh with the 2.5SL and a 2"BL, but no one is currently making a 2"BL for the 05-06's.
#459417 - 19/01/06 07:27 AM Re: bigger tires
No one is even sure the drivetrain can handle 35's.
#459418 - 19/01/06 07:36 AM Re: bigger tires
That too, but he's running a 2wd, so it shouldn't be toomuch of a problem, I am sure the rear end could handle it.
