#46460 - 28/06/03 12:26 PM I left the 4wd on by accident..
AndThenScottSays... Offline
Loc: Greenville, NC
Alright yesterday I drove off the beach, went to the marina to pump up my tires, and then up over a long bridge.. all in all I'd say maybe 3-4 mi max..the only thing is I had 4wd on the whole time and didnt realize it... should I be worried and get it checked out or will it be okay? I didn't realize it was still on till I was on the bridge, and it was a long narrow one.. no room to pull over and start backing up to turn the thing off without causing a big accident. (for those familiar with the NC outer banks it was the bridge over Oregon Inlet)
#46461 - 28/06/03 01:14 PM Re: I left the 4wd on by accident..
Was the transfer case in 4, or were the hubs still just locked ?
#46462 - 28/06/03 03:07 PM Re: I left the 4wd on by accident..
Loc: Greenville, NC
Transfer case was still left in 4hi.
#46463 - 28/06/03 04:25 PM Re: I left the 4wd on by accident..
DocNo Offline
Loc: NoVA
As long as you don't make any tight turns with the transfer case engaged on dry pavement, you should be fine. Just remember, loud "bang" noises = stuff potentially breaking which can = $$$ in repairs.
Driving with the hubs locked will not cause problems. As soon as you noticed the transfer case was still engaged, putting it back into 2HI is more than enough. Once the transfer case is disengaged, there is nothing linking the front wheels together, even if the hubs are still locked. The only reason you would have had to back up was to disengage the hubs - not neccessary to prevent damage from driving on dry pavement.
Murderous Fire!
#46464 - 29/06/03 12:22 AM Re: I left the 4wd on by accident..
XPLORx4 Offline
Loc: San Jose, CA
After driving on Moab slickrock (which is actually not slick at all!) in 4-LO for dozens of miles to the sound of moaning, barking tires, I actually find it difficult to believe that driving in 4WD on pavement is more likely to break something than actually 4-wheeling!
4x4 in uppercase is $X$!!!
#46465 - 29/06/03 12:18 PM Re: I left the 4wd on by accident..
DocNo Offline
Loc: NoVA
Well, that's why I used words like "potentially" and "can". If the tires can't slip and you are making a tight turn, then the exess travel has to be taken up somewhere - if it's in your drivetrain that can be bad - offroad or onroad.
The difference between what you were doing and driving on pavement is on pavement there is no reason to have 4wd engaged...
Murderous Fire!
