#46615 - 18/12/00 06:52 PM Ignition System Upgrade?
BoarderPhreak Offline
Loc: Huntington, NY
I've done a fairly large amount of time working on Volkswagen engines - from stock to all out race (which is currently the state of my race car). I've done a large amount of research on ignition systems to go along with that. However, my experience is limited to normal aspirated engines and without electronic ignition systems. The most often electronic upgrades on these engines comes in the form of replacing the points with a magnetic sensor or installing an electronic ignition computer.
With the Xterra, I'm wondering if the old methods still apply and are beneficial, or if the electronic system just kind of "evens out" your upgrade.
Here's what I was thinking.
Platinum plugs are crap. They have a tiny little electrode and it's main benefit is providing a better spark for weak ignition systems and not fouling as quickly.
I'm thinking about the first tune-up, and replacing the wires with better quality aftermarket ones, replacing the plugs with traditional plugs or maybe multi-electrode ones and looking into the coil and spark plug gap.
By putting in a hotter plug and coil, along with the wires to support it, you can open the plug gap more and get a nice juicy spark. This ensures good, complete combustion and increases power output (read: hp) and efficiency (read: mpg).
Now - will the brain of the X circumvent these modifications? Or will it improve the system overall? Has anyone tried playing with the ignition system?
I'm suspecting that it's not a bolt-on miracle cure by a long shot, but will certainly help boost a typically underwhelming system of most engines out there. Not so much for hp, but at least mpg and knowing you got some good stuff under there.
#46616 - 18/12/00 10:45 PM Re: Ignition System Upgrade?
Huge waste of time and money
Fuel burns just fine in my X, no need to try to improve it.
#46617 - 19/12/00 07:08 AM Re: Ignition System Upgrade?
wqbang Offline
Loc: Auburn, WA
I perfer NGK copper electrode plugs.
Tread Lightly!
#46618 - 19/12/00 07:43 AM Re: Ignition System Upgrade?
Loc: Huntington, NY
I don't think so, Ian. ;>
#46619 - 19/12/00 11:51 AM Re: Ignition System Upgrade?
Call me back when you see an improvement of more than 10%.
I have my faith in Nissan R&D, and doubt anyone will see any performance gains out of the VG33E without resorting to force fed induction, or expensive flow work.
#46620 - 19/12/00 11:58 AM Re: Ignition System Upgrade?
Loc: Huntington, NY
I'm just talking about beefing up the ignition system here... Which is a typically weak link in most stock engines. Will it give you any "bolt-on hp?" No, probably not at all. Maybe 1-2hp if the stock system is really bad. ;>
I'm sure you're right though - the stock X system does what it does just fine. I'm just saying that it can probably be improved - certainly if you make other modifications. ;>
But as for real modifications like a wider throttle body, POP charger type intake, cat-back exhaust and headers - that's a juicy power gain when it's all said and done. Boning up the ignition at that point is icing on the cake.
It won't make your stock motor into a rocket, but it'll definately make it a little more powerful and efficient. At what cost/performance ratio, well, that remains to be seen. Hopefully Spencer Low Racing will provide more facts and figures for our consumption...
#46621 - 26/12/00 06:13 PM Re: Ignition System Upgrade?
Loc: Huntington, NY
So no one's thought of this? Hmmm.
I'd have thought someone at least approached the waterproofing aspect of it...
#46622 - 28/12/00 10:36 AM Re: Ignition System Upgrade?
ZCaptain Offline
Loc: Rockwall, TX USA
I haven't began to modify the X YET -- but I have a lot of experience modifying Nissan Z's.
I think you are on track to make gains in the stock ignition system. Hotter coil, better/larger wires, better plugs (stay w/ NGK), opened wider = better fuel combustion (increase hp and mpg). All factory systems are geared toward the middle of the performance spectrum. Nissan has a long history of improvability. One of the things that keeps me in their stable is that I CAN make it better, faster, stronger. They build a great engine to play with. Go for it. Post what you try (I know you will). If I get to mine soon, I'll post what I do...
Sean 'ZCaptain' Kester
Rockwall, TX
'01 Alpine Green XE 4X2 3Pack
'82 280ZX Coupe (modified)
Rockwall, TX
#46623 - 02/01/01 08:27 PM Re: Ignition System Upgrade?
xmonster Offline
Loc: Abbotsford, B.C., Canada
Hi I am new here so forgive me if I am repeating something that has already been said. A site called Spencer Low Racing has all kinds of bolt on performance upgrades. One package for the xterra includes a new cam, lifters, headers, cat back exhaust and intake. The combined gain in horsepower is said to make the horsepower 220 and torque 237 ft. lbs (http://www.spencerlowracing.com/technotes/technotes_dynoresults.html)
#46624 - 02/01/01 10:30 PM Re: Ignition System Upgrade?
Loc: Huntington, NY
One thing to watch for in ignition wires, like those from Spencer Low Racing is that they're non-supressive. That is, they're not shielded for noise and will make your radio and communications gear near useless - or certainly noisy.
I'm probably going to change the plugs, coil and wire at some point, but I'm looking at the Spring or early Summer for these mods. I'll be doing research in the meantime, though.
Thanks for the input - that's pretty much what I was thinking.
#46625 - 03/01/01 07:11 AM Re: Ignition System Upgrade?
xmonster Offline
I don't know if they make one for the xterra but Jacobs Electronics makes a "Digital Controlled" ignition set that they swear will increase power and economy. I had one on an old mustang of mine and it worked well. It consists of a new coil, wire, and control box. www.jacobselectronics.com
is supposed to have the details although I have never visited the site.
#46626 - 03/01/01 08:49 AM Re: Ignition System Upgrade?
Loc: Huntington, NY
Yep, I've had the Jacobs system in a VW and it does certainly help. I don't have that system anymore, but I still have the coil. The wires were replaced with Accel 8.8mm yellow jackets.
#46627 - 09/01/01 08:01 PM Re: Ignition System Upgrade?
coolerman Offline
Loc: Paint Lick, KY USA
I hqve the Jacobs Omni-Pak installed on a 1991 Pathfinder. It does make a difference! Jacobs claims 8-10 hp for the VG30E engine. All I know is I get 1-2 mpg better miliage and an increase in power starting in the 2000 to 4000 RPM range. I also used the orginal cap & rotor button for 114k miles, just cleaning them every 10k or so. I run AC plugs gapped @.055. The 2000 Xterra I have has a different igntion system from the Pathfinder. It has a HEI system similar to the GM units so would not show as much of a gain if replaced. By replacing the stock wires with a quality set you can increase the plug gap by .010 without changing the coil. You can also increase the timing a couple of degrees without the computer trying to compensate.
The comment about platinum plugs being designed for weak ignition systems is not correct. They were designed to last for 50k before replacing and they will. They are also designed to require less power to fire reducing ignition noise and coil heat.
Coolerman
1991 XE V6 5sp Pathfinder
2000 SE V6 Auto Xterra
1972 Toyota Land Cruiser
Coolerman
Past Member of MAXC/TLCA
2000 V6 Auto SE Xterra
2013 Altima SV
1971 Toyota Land Cruiser
#46628 - 10/01/01 09:29 AM Re: Ignition System Upgrade?
Loc: Huntington, NY
Read that one more time. "They are designed to require less power..." Like I said, they're good for weak ignition systems. ;>
Nothing beats quality wires, a hot coil (spark wise) and good plugs with a nice gap.
#46629 - 11/01/01 07:13 PM Re: Ignition System Upgrade?
ElectroKen Offline
Loc: Shelton, CT
The coil on the VG33E is integrated into the base of the distributor. Take a look - only 6 wires on top of the cap. Nobody is installing that old Accel Super Coil from the back of their garage into their X without a fight.
#46630 - 11/01/01 08:15 PM Re: Ignition System Upgrade?
Loc: Huntington, NY
Well now, that's a bummer.
Perhaps another, similar fitting part might serve to replace the cap/rotor - or worse comes to worse, a new distributor...
But I doubt I'd go that far. If you're gonna do that much work, you might as well add a cam, headers, throttle body and so on to make it all worthwhile.
Some day maybe, but not today.
#46631 - 27/01/01 09:49 PM Re: Ignition System Upgrade?
ATATBOY Offline
Loc: Sacramento Ca U.S.A.
I called Jacobs last week and they said that there is no inprovement for the X right now. Burke
Do not mettle in the affairs of Dragons,
For you are crunchy and taste good with Ketchup.
#46632 - 04/02/01 04:58 PM Re: Ignition System Upgrade?
defibvt Offline
7
Loc: AZ
I have been doing some research too. I am going to upgrade plugs to split fires and upgrad wires and then get a POP charger. A friend did this with his JEEP Cherokee and improved his fuel mileage by 2 mpg. I know, I know some of you may think split fires are crap but I have used them in all my vehicles and have noticed a improvement in power and mpg.
'00 Solar Yellow XE
Automatic
3-pack
#46633 - 04/02/01 05:03 PM Re: Ignition System Upgrade?
why would anyone want to upgrade their ignition? Its useless unless you are going to supercharge it. Stick to bolt-ons, like Intakes and Exhaust.
I USE MY "X" TO TOW MY RACE CAR AT THE TRACK.
#46634 - 05/02/01 12:39 PM Re: Ignition System Upgrade?
Loc: Huntington, NY
LOL.
Do I really have to answer this? Sure, why not...
If your ignition system is weak, then you're not burning all of the fuel mixture that you could be. That means lost power and lost fuel economy.
Yes, it helps to have other modifications, but you'd be surprised at how much an affect your ignition can have on overall engine operation.
As for "sticking to bolt-ons" well, that's just a silly comment. Do you consider a "Type R" sticker a bolt-on also?
#46635 - 05/02/01 01:47 PM Re: Ignition System Upgrade?
LOL.
so you mean to tell me spending money on Wires, Plugs, and ignition boxes is better than buying exhausts and intakes? Oh yeah and Bosch +4 and Split Fires give you 30 hp at the wheels.
2000 X V-6 2WD
mods: JWT Pop Charger (soon HKS CAT-BACK)
i use my X to tow my race car to the track.
#46636 - 05/02/01 01:50 PM Re: Ignition System Upgrade?
LOL.
Nah..im talking about Roof Racks and Brush Guards and Calvin pissin' on Ford or Chevy Stickers...thats real "bolt-on" power!
2000 X V-6 2WD
#46637 - 05/02/01 01:57 PM Re: Ignition System Upgrade?
Loc: Huntington, NY
I never said it was "better." It helps, and it's part of "the complete package" - if I were to modify other parts of the engine as far as intake and exhaust, you betcha I'd upgrade the ignition. Even without those mods, it's an improvement - albeit a small one. Depends on how hardcore you want to go.
Remember - "how fast do you want to go?" is in directo correlation to "how much do you want to spend?"
What kind of car do you race, again? You should know these things if you "race."
#46638 - 05/02/01 02:29 PM Re: Ignition System Upgrade?
see, thats the old way. I dont own a Mustang or Z-28. Its how fast can you go with the little money you have..all this talk is making me hungry, i think its time to make a run at the Boarder.
2000 X V-6 2WD
#46639 - 05/02/01 03:12 PM Re: Ignition System Upgrade?
It has nothing to do with how fast you can go, anyone can drive in a straight line.
It's how fast you get into the corner, how late you brake, and how fast you get out of the corner. And for me, that's much more fun on 2 wheels than 4.
Regards,
Ian
