#468501 - 03/03/07 12:19 PM Mounting Hi-lift to sportrack
I just purchased a 36' Hi-lift jack and I want to mount it to this
I bought 3 quickfists, but I am afraid that over time it might come loose....anybody have any ideas...or thoughts?
thanks
#468502 - 03/03/07 07:02 PM Re: Mounting Hi-lift to sportrack
As that rack is basically the same design as a Yakima it looks like, then the Yakima High Lift jack mounts might work on there.
http://www.yakima.com/Product.aspx?id=74
$63 here:
http://www.docs.outdoorsports.com/item.aspx?dept_id=20&product_id=8007077
#468503 - 03/03/07 07:24 PM Re: Mounting Hi-lift to sportrack
thanks....
#468504 - 05/03/07 09:47 AM Re: Mounting Hi-lift to sportrack
Yeah, I personally wouldn't use the quick fists for holding anything as heavy as a hi-lift. I was going to go that route originally and after ripping one of the quick fists I felt they wouldn't be safe.
#468505 - 05/03/07 05:06 PM Re: Mounting Hi-lift to sportrack
So how did you mount yours then...
#468506 - 06/03/07 08:01 AM Re: Mounting Hi-lift to sportrack
I don't have a basket, but I ended up using Yakima X-Towers and converting them to hold my 60" Hi-Lift to the stock rack side bars.
I now have a 48" hi-lift mounted to the Shrock bumper.
#468507 - 06/03/07 08:54 AM Re: Mounting Hi-lift to sportrack
pictures on a yakima
#468508 - 06/03/07 09:42 AM Re: Mounting Hi-lift to sportrack
Thanks for those pics they help....
is your jack a 48"?
I just bought the xtreme hi-lift 48" how many brackets did you use it only looks like 2....is that right?
What kind of rack is that? smile
#468509 - 06/03/07 10:11 AM Re: Mounting Hi-lift to sportrack
only used the 2 brackets and hardware that came with the Yakima HiLift mount Kit . The Jack is the 60 inch length. If you click on the view full size button you can see the shovel mount as well.
#468510 - 06/03/07 05:02 PM Re: Mounting Hi-lift to sportrack
so do you keep the shovel and Hi-lift up there all the time?
#468511 - 06/03/07 05:17 PM Re: Mounting Hi-lift to sportrack
HiLift has a provision for a padlock to be placed on one mount point. The shovel is usually off since it uses large plastic winged nuts with no security provision. But I did leave it on for a week after a trip to the mountains and no one stole it. I guess the key is to use a good rusty shovel. smile
#468512 - 07/03/07 04:33 PM Re: Mounting Hi-lift to sportrack
So besides the shovel the hi-lift stays up there all the time?
#468513 - 07/03/07 07:15 PM Re: Mounting Hi-lift to sportrack
Are the hi-lift mounts metal or plastic?
#468514 - 07/03/07 08:21 PM Re: Mounting Hi-lift to sportrack
hi lift is up all the time.
Mount brackets are metal but the inserts that wrap around the rack are made of plastic. This seems like it would give you the lattitude that you need to fit it to your rack dimensions.
#468515 - 07/03/07 08:25 PM Re: Mounting Hi-lift to sportrack
But the problem is the diameter of my tube is 1"1/4 and the Yakima rack is 1"1/8th in diameter so my rack is a 1/4 inch bigger...do you think it would pose a problem?
#468516 - 07/03/07 09:18 PM Re: Mounting Hi-lift to sportrack
1/8 th inch reaming of a plastic insert should not be difficult. Your mileage may vary. smile
#468517 - 08/03/07 03:18 AM Re: Mounting Hi-lift to sportrack
then I was thinking of this I say on the newx website..anyone have experience with these?
http://www.fourtreks.com/hi_lift_roll_bar_mounts_1_75_.html
here is a pic also
they make hi-lift/shovel/axe mounts varying in sizes from 1"-2.25"
I figure since my rack has a diameter of 1 1/4" then it should fit...
#468518 - 08/03/07 05:49 AM Re: Mounting Hi-lift to sportrack
They are very expensive, but should work.
The mount to hold the jack, shouldn't cost more than the jack. smile
#468519 - 08/03/07 06:46 AM Re: Mounting Hi-lift to sportrack
Andy -AKA- KaiOtiK with NCCX uses those and has been happy with them. He has his mounted across the front of the rack tubes just behind his light bar.
#468520 - 08/03/07 12:23 PM Re: Mounting Hi-lift to sportrack
I think the picture of his truck with the hi-lift mounted is on fourtrek website..
here it is
http://fourtreks.com/customer_s_applications.html
