113
#46958 - 20/02/02 10:18 AM
New Airaid Intake for Xterra's!
Loc: Billerica, MA
I just got off the phone with an technical advisor from Poweraid, and he said next week they start shipping the new Airaid intake for the Xterra. The kit uses the stock factory bottom half of the airbox (along with the intake tubes), but replaces the top half and comes an adaptor/cone air filter. This is a "sealed" unit, so heat soak or water splashing up into the engine compartment should not be a problem. Their list price was $219, but he said dealers like www.truckperformance.com would have them cheaper.
#46962 - 20/02/02 03:56 PM
Re: New Airaid Intake for Xterra's!
Loc: Aliso Viejo, Ca,
I've emailed them a couple of times myself. Just been waiting for them to release. I looked at TruckPerformance.com and found the airaid for the Xterra list. web page $153.00 However, it shows that it's ships in 24hrs. How can that be right if airraid hasn't released it yet. Jim
#46963 - 20/02/02 06:51 PM
Loc: NH
Originally posted by Caver-X: I've just about given up on SLR's cold air box. Every time I call them its "it'll be out in a couple weeks". I want a high flow intake, but one that I can mate with a snorkel and still be waterproof. I gave up on waiting for it, sold the IV intake, and bought the stillen.
#46964 - 21/02/02 04:01 AM
Loc: Billerica, MA
Originally posted by Caver-X: Do you know if its actually a sealed box, or if its just has walls and rubber to seal against your hood. It's a sealed unit. The new top portion (cover, adaptor, cone air filter) snaps on the lower stock portion of the airbox. There is no seal up against the hood.
#46965 - 21/02/02 07:58 PM
Loc: Independance mo usa
I have the Poweraid spacer on my 2000 x
IT NEVER FAILS: If a thing is done wrong often enough, it appears right. www.highboyz.com
#46966 - 21/02/02 07:59 PM
#46967 - 22/02/02 04:25 AM
Loc: San Antonio, TX
the spacer you have is for the 3.3L frontier engine part number right? air raid doesnt list a part number specifically for the xterra yet that i know of. what are the benefits of the spacer?
#46969 - 22/02/02 10:14 AM
Hey Stormy,
How much did it set you back? I have been looking at getting an intake, and would be interested to also know if you have seen any performace gains? Thanks, Kevin
"From this day forward September 27th, 2002 all post are dedicated to Ian himself"
#46970 - 23/02/02 08:02 AM
Loc: Sugar Land, TX
There is a guy on eBay who will occasionally sell that exact same Stillen kit. Going rate was about $189.
#46971 - 23/02/02 08:01 PM
yes the part num is the one for the frontier works great just make shur to reset you ecu
#46972 - 24/02/02 04:32 AM
Loc: Sigonella, Sicily, Italy
Resetting your ECU does not help your ECU adjust quicker to changes. Your ECU is constantly evaluating the condition of the engine sensors and making adjustments. By resetting the ECU you are causing it to go back to factory defaults and relearn EVERYTHING instead of just letting it adjust for the air intake change. You will only get shitty gas mileage and poor power for 30 or 40 miles until the ECU re-learns what's going on in your engine. Leave the ECU alone unless you are changing something inside the ECU.
Fred
"What are you gonna make me do? Wack a guy? Off a guy? Wack-off a guy? Cuz I'm married!" - Peter (The Family Guy)
#46973 - 24/02/02 06:04 AM
Loc: NH
Originally posted by The X Factor: Hey Stormy,
How much did it set you back? I have been looking at getting an intake, and would be interested to also know if you have seen any performace gains? Thanks, Kevin $218 + shipping
#46974 - 24/02/02 10:48 AM
Loc: Bakersfield, CA
Originally posted by xoc: Increased intake velocity. XOC- Tell me how it increases the intake velocity. Also, do you have any dyno results that actually show it works? I've heard lots of 'I feel faster, therefor I am arguments', but from all the dynos I've seen, they show no improvment whatsoever, in fact, I've seen slight hp losses. -Chris
This is the place brillant minds assemble to carefully pool ignorance with questionable logic in order to reach unworkable solutions.
#46975 - 24/02/02 11:16 AM
not true about the ecu because I lost gas mileage until I reset it. I wated 3 days before I did it and it made a big diff
#46978 - 07/03/02 04:03 PM
Loc: Fort Worth, TX
Originally posted by xoc: Never mind, I had them confused with a velocity stack. It seems the PowerAid Spacer is nothing more than an expensive Tornado.[/QB] My thoughts exactly. Why would you have to wait for an Xterra part number. The two engines are identical. Either way don't waste your money. I have talked to several people who noticed no change whatsoever.
#46979 - 09/03/02 01:20 AM
Loc: Houston, Tx.
Originally posted by xoc: Originally posted by PismoTaco: [b]XOC- Tell me how it increases the intake velocity. Never mind, I had them confused with a velocity stack. It seems the PowerAid Spacer is nothing more than an expensive Tornado.[/b]I recently read an article on the Tornado for SUVs...It sure read good, but I take it there are no advantages for installing this on our trucks?
