131
3
#47505 - 17/09/02 11:51 AM
Engine problems
Loc: Colorado Springs ,CO,USA
Ok,I have taken my x into the local Nissan dealership with a multiple cylinder misfire, they are first trying a fuel injector flush then say the next step is replacing the fuel injectors themselves and want over $1000 bucks to do the replacement. I am out of warranty with 78K on the truck. This seems too early to replace the injectors to me on a 2000 model year. What have been peoples experience with these and Nissans. Is this a job that has to be done by a certified tech, I'm pretty engine savvy, can I do it myself and save $400 in labor?
Formerly: '00 black XE ARB, Big O XT's Now: '04 Ttan LE CC "Drink it up, this ones for you, it's been a lovely cruise"-Buffett
#47507 - 17/09/02 09:49 PM
Re: Engine problems
Loc: Utah
Have the timing and idle speed checked and adjusted if necessary. After that try a new Distributor Cap (and check the rotor). If you do it yourself it will only cost you about $20-$30 (for the cap). If that does not fix it then let the dealers do what they want. Only trust a dealer as far as you can throw them.
#47508 - 18/09/02 07:23 AM
Re: Engine problems
I've always been that same way '97. I have replaced the cap, rotor, wires, plugs etc. the truck has been running bad all summer, stalling at stoplights etc. When I got it back from the dealer after nearly $300 of diagniostic work they told me the distributor is what needs to be replaced. I guess when the tech pushes on the coils the rough idle and stalling goes away. I did a little reasearch into the injectors and priced them out on xterraparts.com compared to my dealer, my dealer ha a 40% markup for the parts. So I have a feeling I'll get the dist through them. I also went in with a list of TSB's from the internet and the dealer had only seen about half of the ones I had, very reassuring.
#47509 - 18/09/02 11:02 PM
Re: Engine problems
Loc: New Zealand
Both jobs seem like easy DIY's, but is the problem caused by the injectors or the distributor? For $300 of diagnostics they better be right, whatever the cause is.
-Paul 2007 Nissan X-Trail New Zealand (ex San Diego)
#47510 - 19/09/02 08:42 PM
Re: Engine problems
Loc: Calif
So, did they due the injector cleaning for the $300 ??
Sometimes you feel like a Nut, sometimes you don't.
#47511 - 20/09/02 07:31 AM
Re: Engine problems
Yes they did do that but it didn't help.
#47512 - 21/09/02 07:40 PM
Re: Engine problems
Got a new distributor, put it in, purrs like a kitten again. The install was very easy, I can't even tella difference in the timing although I probably need to adjust it. Problem Solved!
