Page 2 of 2 < 1 2
#48287 - 30/06/02 06:50 PM Re: K&N AirCharger Installation and Review...
xcanuk Offline
Loc: Mtl. Que. Canada
Originally posted by Olegkha:
Ian: you are not affraid to suck in water?
Just installed one myself after reading the review, I did address the water problem in my own way.
Here
link Fixed
member of http://www.soxc.org
#48288 - 01/07/02 05:30 AM Re: K&N AirCharger Installation and Review...
Y02X Offline
Loc: Michigan...Land of humidity, H...
And your URL does what?
http:///
-matt mc
#48289 - 01/07/02 05:28 PM Re: K&N AirCharger Installation and Review...
xcanuk Offline
#48290 - 03/08/02 01:49 PM Re: K&N AirCharger Installation and Review...
bronx Offline
Loc: California
Has anyone have the Check Engine Light on after installing the K&N Aircharger Kit??? Is it because the Air Temp Sensor is not plugged back in? I read the instructions... it does not say anything about install the Air Temp Sensor back in...
http://www.cardomain.com/ride/2327321
#48291 - 03/08/02 03:08 PM Re: K&N AirCharger Installation and Review...
Big Daddy Chia Offline
Loc: Austin, TX
Actually it does. There is a small hole on the back of the filter itself.
Scott "Chia" Holland
"God created man. Sam Colt made them equal"
#48292 - 03/08/02 09:12 PM Re: K&N AirCharger Installation and Review...
John L. Offline
Loc: Tampa, Fl
FYI, I just installed a HKS intake and left the temp sensor in the factory location and I didn't get a check engine light... Could be something else... Let us know if putting it in the K&N makes the light go off.
John L.
#48293 - 04/08/02 12:44 PM Re: K&N AirCharger Installation and Review...
bronx Offline
Loc: California
I found where the Air Temp Sensor goes. Thanx.. I still have the Engine Service light on. I called the techs at my dealer but they said it because of the aftermarket intake. I have to set an appt on Monday. Eventually it will go away after 30 starts.
Is this guy for real??? [Freak]
#48294 - 04/08/02 01:31 PM Re: K&N AirCharger Installation and Review...
x2see Offline
Loc: Independance mo usa
I looked at the k&n first but I went with air raid. I like it better cause it uses the bottom of the stock air box And I have there tbs
IT NEVER FAILS: If a thing is done wrong often enough, it appears right. www.highboyz.com
#48295 - 04/08/02 04:06 PM Re: K&N AirCharger Installation and Review...
xcanuk Offline
I called the techs at my dealer but they said it because of the aftermarket intake. Eventually it will go away after 30 starts.
No light came up after my install. Only "if" you figure its a false code, just disconnect the negative from your battery for a few hours (overnight).. that will clear the light. See the dealer if it comes on again.
#48296 - 04/08/02 07:21 PM Re: K&N AirCharger Installation and Review...
Loc: Austin, TX
If your going to draw more air in why would you want to keep the bottom of the stock intake in. Thats just restrictang the air you could pull in if you went the K&N kit.
#48297 - 18/08/02 02:39 PM Re: K&N AirCharger Installation and Review...
bronx Offline
Loc: California
I just came back from the dealer for fixing that Service Engine Soon... The Service Tech ended up talking me into getting 30,000 mile service checkup + engine diagnoistic... Grand total $343.00. It also included a free Rental (Mitsubishi Lancer and Car Wash)... Service Advisor said that the cause might be the K&N Filter cuz he notice a hissing vacuum when we left the service lot. Now he wants to jack up the service to maybe a AAC Valve being replaced. Has anyone have this much problem with the AAC VALVE or their K&N Aircharger pt# 63-1032
mad [Crybaby] [Freak] mad [Huh?]
#48298 - 18/08/02 03:57 PM Re: K&N AirCharger Installation and Review...
xcanuk Offline
As far as I could tell, (as well as by asking others), the "hissing" is normal. I only notice it while idling at a stop light, it turns into a nice growl when I get to 2000- 2500 rpm. I thought it was some type of air leak at the beginning and kept rechecking my connections and clamps.
Its been on (K&N charger) for 2 months now, including a 2 week road trip, nothing indicates any other problems due to the install, I've seemed to have gained a mile or two to my MPG.
#48299 - 18/08/02 05:03 PM Re: K&N AirCharger Installation and Review...
bronx Offline
Loc: California
Thanx xcanuk... you've been helpful!!!
#48300 - 29/09/02 03:48 PM Re: K&N AirCharger Installation and Review...
mr_omerta Offline
Loc: Pittsburgh, PA
Just installed mine yesterday, got to test it out quite a bit since. Easy install, it goes well with my Calmini exhaust, nice growl to it. I've noticed a slight improvement in gas mileage, a little extra oomph, too... I recommend it to everyone, especially those who have lost some power/fuel efficiency due to larger tires (I'm running 265/75/16's).
The only thing I don't like is the hiss, but usually my stereo is too loud to even hear it!
UPDATE: Just an FYI, my Xterra just passed State Inspection with the Aircharger...
#48301 - 04/10/02 09:09 PM Re: K&N AirCharger Installation and Review...
yz250fguy Offline
Loc: churning dirt on earth
I am not an expert, but believe me when I say K & N filters are bad news.
I have ridden motocross now for 15 years, and you need to wash your foam filter and re-oil every ride for the filter to be effective in removing dirt/dust.
We did a test a few years back. You should do the same. Take some vaseline and smear it somewhere visible in the plumbing after the filter. Ride around for 3000 miles. Open up and look at the smear, it will be covered in crap.
Do the same with a stock setup, and it will be clean.
Anyone who installs a K and N is a fool, and will kill the engine prematurely. No doubt.
To let more air in, you have to let more dirt in, its just common sense. Plus, if you wring it out after you wash it like a clown , you'll ruin the invisible webbing, allowing more crap to get through. And never use gas to clean it, use kero. Gas will eat the filter.
Go back to stock if you value your engine.
I bet you use fram oil filters also!
YZ
YZ250F GUY
#48302 - 04/10/02 10:00 PM Re: K&N AirCharger Installation and Review...
Ahh... another K&N sucks, Fram sucks ranter.
Have you ever wondered how those companies stay in business if what they sell is complete crap ?
#48303 - 04/10/02 11:55 PM Re: K&N AirCharger Installation and Review...
ChuckH Offline
YZ
Maybe you could explain why I spent a week following another Xterra through the dustiest conditions I have ever seen and had absolutely no dirt or dust in my intake past the filter? I intentionally looked inide the intake tubes and they were totally clean. It was never that clean before. This is picture of Rrdstarr's filter (we went on the dust from hell trip together). Mine looked pretty much the same. Neither one of us had any dirt past the filter.
Like XOC has said, K&N would be out of business by now if their filters weren't any good.
#48304 - 05/10/02 07:38 AM Re: K&N AirCharger Installation and Review...
mr_omerta Offline
Loc: Pittsburgh, PA
Nothing beats oil filter insults...
#48305 - 05/10/02 04:58 PM Re: K&N AirCharger Installation and Review...
rrdstarr Offline
Loc: Tacoma
[b]I am not an expert, but believe me when I say K & N filters are bad news.
YZ
[/b]
My comment is that this K&N Aircharger actually traps dirt better than the K&N replacement filter for the stock airbox!
-Rick
Page 2 of 2 < 1 2
