#495389 - 26/03/10 06:04 AM Wrong transmission fluid...
Forrest77 Offline
Does anyone know what kind of damage can be done if the wrong transmission fluid was used?
#495391 - 26/03/10 07:35 AM Re: Wrong transmission fluid... [Re: Forrest77]
granitex Offline
Loc: Columbus. Oh
depends on what atf, and for how long.
#495394 - 26/03/10 10:48 AM Re: Wrong transmission fluid... [Re: granitex]
Forrest77 Offline
Atf Type F for about 7,000 miles.
#495399 - 26/03/10 06:28 PM Re: Wrong transmission fluid... [Re: Forrest77]
vacsimile Offline
Loc: Middle of Nowhere
Not sure about the damage... you'll probably just have to see if any problems develop later on. I would think the worst case would be damaged friction discs, requiring a rebuild. I kind of doubt it though. For a drain/refill you only get out around half of the fluid, so you should have a mix of fluids in there. If you want to completely remove the type-f, it may require changing the fluid several times in succession. It will be kinda pricey.
The only thing I can prove is there is no proof.
#674122 - 19/12/10 07:56 PM Re: Wrong transmission fluid... [Re: Forrest77]
ASTE25 Offline
Loc: New Market, Alabama
Type-f fluid's main difference is that it has a "grabbing" agent in it, to promote better clutch engagement. I used to use it in General Motors transmissions (they call for Dexron fluid)I rebuilt for my hot rods (when I was a kid). I think as long as you flush it all out and put the right stuff back in, you should be ok. I'm not sure if the X's have a drain plug in the converter, but if it does I'd drain it too. The whole system should use around 11-12 quarts. If all you did was top it off with Type-f fluid, I'd say just let it ride, you should be ok.
2011 S 4X4 Night Armor 6 speed
