#498905 - 19/12/07 01:27 PM steering box
when yall do an SAS do you use the stock steering box or do you swap it? i know i need a drop pitman arm and i cant buy just the pitman arm for the xterra. im thinking about running a cherokee steering box with a hydro assist.
#498906 - 19/12/07 06:57 PM Re: steering box
you use stock pitman arm, and stock steering box. nothing changes.
#498907 - 19/12/07 07:38 PM Re: steering box
Kaiser Offline
I reamed out my pitman to fit Chevy 1/2 and 3/4 ton draglink ends... but it's the stock pitman and stock box.
#498908 - 19/12/07 07:52 PM Re: steering box
run a hydro assist with the stock steering box, if you're planning on needing the assist. That's what I'll be putting on next month.
You won't find a drop pitman for the Nisan box, though. So make due with the stock, or replace the box; your call. You most likely won't need a drop pitman.
#498909 - 19/12/07 07:59 PM Re: steering box
oh ok thanks. are yall running tie rod end or hiem joint steering?
does anybody make a hydro assist kit for the xterra?
#498910 - 20/12/07 07:00 AM Re: steering box
TREs on mine.
No, no one makes a ram assist for an Xterra. All that needs to be fabricated.
#498911 - 20/12/07 08:40 AM Re: steering box
No Kits have been made but PSC does take a Nissan box and port it for Hydro Assist.
http://www.pscmotorsports.com/
