I have a leaking side flange oil seal on my front differential. Can this be replaced without removing the entire front final drive? Is it possible to disconnect the left front axle at the left side flange and remove the side flange to replace the oil seal? If it is not this simple I'll just keep checking and adding oil to the differential housing. It's on a 2002 SE 4x4.
You can't tell which way the train went by the tracks it left behind.
