#510341 - 13/10/05 10:17 PM Rear Shocks on 05 OR
Hey guys... I've noticed that I am "bottoming" out a lot when I have any type of cargo or passengers in the X. The shocks are not absorbing very well and the cab is hitting the axle stoppers (sorry for incorrect verbage) really hard.
This normal? I would think with the Bilstein Shocks that this would not be a problem... especially since the front set seem to hold up great!
#510342 - 14/10/05 02:31 AM Re: Rear Shocks on 05 OR
Doesn't sound normal at all. How much weight are you carrying around in it?? I'd take it back to have them look at it.
#510343 - 14/10/05 03:46 AM Re: Rear Shocks on 05 OR
NSANY Offline
Loc: Scenic NJ
Check a few other posts on this. Bottoming out isn't a function of the shocks (they keep the tire on the ground), rather it's the springs that will prevent bottoming out.
A few people have noted that the 05 X appears to have softer rear springs that it should, resulting in some bottoming out.
2005 Nissan Xterra Off-Road / 6MT / KH3
Wondering what NSANY means???
#510344 - 14/10/05 05:36 AM Re: Rear Shocks on 05 OR
hattrik21 Offline
Loc: Lewisville, Texas
Yes very much so. frown One of the few Issues I have with the new 05's.
SWXC Member # 65
TMTC Member # 1795
www.Texas-X.net
www.TheNewX.org
#510345 - 14/10/05 07:20 AM Re: Rear Shocks on 05 OR
Some also state that it's not so much the stiffness of the springs, but the fact that the bump stop just doesn't give much room.
#510346 - 16/10/05 08:01 AM Re: Rear Shocks on 05 OR
fastdrmr Offline
Loc: SLC, UT
On the uptravel of the axle to the bumpstop there is only 2"... not good! All the different models of Xs suffer from this so it is not a Bilstein related issue.
KE7AEY
#510347 - 16/10/05 04:43 PM Re: Rear Shocks on 05 OR
NSANY Offline
Loc: Scenic NJ
Just out of curiosity, what was the axle travel on the previous generation Xterra? My buddy had a 2000 Xterra XE, and he never had this sort of problem, even before we put the Calmini add-a-leaf syste in.
#510348 - 17/10/05 11:23 AM Re: Rear Shocks on 05 OR
Heh. It's a lot more than "some". I'm somewhere between shocked and disgusted at how poorly my '05 X wheels with any kind of load in the back compared with my previous '92 Trooper. I hope somebody comes up with a less drastic solution than the 5" Calmini lift which was the response I got to my bitching about this same problem...
#510349 - 17/10/05 01:44 PM Re: Rear Shocks on 05 OR
Trimming the bumpstops about 1" seems like a decent temporary solution; at least it would give you 50% more rear upward travel than we already have. [Freak]
#510350 - 17/10/05 02:15 PM Re: Rear Shocks on 05 OR
Do the shocks have enough upward travel in them to do this? I know someone was going to check, but I have not seen a response to this.
Also there are a few companies coming out with 2.5 and 3" lifts.
And to be honest, I bottom out more driving down the road hitting pot holes than I do off-road.
