I guess I must have misunderstood your original post, because if the bulb holder is the only thing that is broken and if they put in a new instrament cluster, you should still have access to the old cluster. There are at least a dozen bulb holders the same size as the turn signal bulb holder that you could just switch from the old cluster to replace the broken one, unless they screwed up the circuit board bulb socket, which is a totally different situation.
