#518555 - 23/01/06 08:29 AM Airbag Disengage Switch
Is there a way to disengage the airbags on an 06? I'm worried that when I go off roading, I'll start to tip (or tip over) and all the airbags will blow, costing more $ than necessary. I know I've seen disengage switches in some cars' gloveboxes...
#518556 - 23/01/06 08:38 AM Re: Airbag Disengage Switch
This has been discussed before. Well if you are tipping over I think Airbags will be the least of your worries.
But the front bags won't go off if you are rolling over.
#518557 - 23/01/06 09:29 AM Re: Airbag Disengage Switch
Couldn't find it in a search.
I have the side airbag package and I don't want them all blowing if I'm tipping over at a snail's pace. I'f I'm rolling at 90 on the highway, that's a different story...
#518558 - 23/01/06 10:52 AM Re: Airbag Disengage Switch
Hmmm. Not sure then. You need to ask someone who has the shop manual.
Anyway I see you are Upstate NY come check out the Upstate New York Xterra club.
www.unyxterra.com
#518559 - 23/01/06 11:35 AM Re: Airbag Disengage Switch
If you roll over sideways, again, the airbags going off will be the least of your worries. Either way, even if it's a slow roll, and you'll likely cause enough damage to total the vehicle.
#518560 - 23/01/06 02:06 PM Re: Airbag Disengage Switch
X-Ego, check out:
http://www.airbagswitches.com/
Haven't had a chance to check it out in detail yet, but I've been hosed by airbags twice and might consider it...
