Originally posted by Xtopher:
For the rear, put the jack under the spring pack @ the Ubolts.
For the front at the wheel end of the a-arm..
If you have a 2000 (or 15" rims) you cannot jack from the leaf pack, jack won't fit under if the tire is flat, you have to use the rear axle.
If I remember right, if I tried the front A arm, the jack would want to kick out..caution should be used.
