#52488 - 09/03/07 01:26 PM ARB bumper question
hey guys, just need a little quick info here. i did a search in this section but im not sure i always search the "right" way cuz i rarely have much luck when i do. anyway, to the point...
i have a line on an ARB bumper. its coming off a 2000 and i have a 2004. i think the front ends are basically the same other than cosmetic but i just wanted to verify if anyone knew for sure if it would fit.
#52489 - 09/03/07 01:31 PM Re: ARB bumper question
The hood line on the round headlight X's is taller, so the bars and match to the grill lines meant for the square light version will be about 1.5" low for the hood line and grill line of the rounders.
The frame horn ends are a bit different too, but that's an easier work around.
Hope that helps.
#52490 - 09/03/07 02:29 PM Re: ARB bumper question
If I may quote myself:
Originally posted by skaggs396:
No I dont think he is messing with us. Claus is quite a regular around here. Maybe he just has not had time to check his email.
One thing to note is early production of the Xterra ARB 00-01 bumpers do not fit on 02-04's because of the uprights (triangular things) on the bumper. They interfere with the grill on the 02-04's. But at some point I think they started just using the uprights that fit the 02-04 and just had one bumper that fit all years. Check this picture:
as long as the uprights are the newer production with them angled forward to allow for the grill they are good to go on your truck. [ThumbsUp] Otherwise, youll be cutting your grill
#52491 - 09/03/07 02:38 PM Re: ARB bumper question
ahhhh, thanks for the help guys, glad i asked.
appreciate it! [ThumbsUp]
#52492 - 09/03/07 04:08 PM Re: ARB bumper question
They will fit fine but require trimming the plastic. I would recommend it if you have a line on a good deal.
Good luck! [ThumbsUp]
