Ok, some of the stuff I don't understand.
My Build List...Starting to order parts soon as my old trail rig is sold.
1. New Windshield
-Did you crack yours?
2. Channel 9 CB Fiasco
-Huh?
3. Rear CB Antenna Mount
-Not a big deal. Go the expensive route and get the Shrock rear bumper with antenna mount, or you can get the a mount that goes between the pillar and rear hatch.
4. Transfer Sirius Account
-Wouldn't really call that a mod.
5. Dual Battery Set Up
-There is no room under the hood, so the 2nd battery will have to go in the back some place.
6. Air Compressor Mount
-You won't be able to fit it "Under" the air box, but if you get a sealed compressor (ie. ViAir) you could mount it vertically using 'L' brackets right next to the air box. This is where I plan to mount mine. I also have a 150psi pancake tank that is going to mount where the spare use to be.
7. Shower Exchanger Mount(through grill)
-Huh?
8. Skid Plates
-Good idea... Shrock or Black Panther
9. Front Bumper/ Shrock
-Good idea
10. T-Max Winch
-Not a bad winch for the money.
11.Rear Bumper and mount cans and hi-lift
-I don't know if any of the current rear bumpers (Shrock or Calmini) have can mounts.
12.Body Lift??
-AC has the 3" lift currently. Last time I talked to them they didn't know if a 2" would be made.
13.Tires
-Good
14.Rims??
-So far there have only been two found that fit without spacers. They are both made by BM.
15.Other Suspension?
-You have some options depending on how much you want to spend.
--AC - Coils (front), Shackles or AAL (rear) (about 2.5-3" lift)
--Calmini - Spacers (front), Shackles or AAL (rear) (about 2.5" lift)
--Daystar - Spacers (front), Shackles (rear)
--Calmini - 5" lift (still only taking pre-orders). Rumor has the price around $1600
--SLR - 5" Lift (There is at least one X running around with this lift). Rumor on price is over $5000 with coil over shocks.
---TC/PRG - Total Chaos Upper Control arms w/ PRG Coilover shocks (front), Deaver spring pack (rear) (about 3" lift).
16.Pinon Seal Leak/ Warranty Item(Dissapointed)
-You are the 2nd person I heard with this problem. It seems to be a quick fix for the dealer.
17.Spare CVs and Tie Rods
-Not a bad idea. Good news, the front axle shafts (and CV joints) are the same on both sides so you only need one for a spare.
18.Trim rear Bumper ends/ modify.
-Why?
Phase II (When Available)
1. Diff Gears
-Would be nice.
2. T/case Gears
-Would be even nicer.
3. Front Locker
-Not as nice as new TC gears...but I would like.
4. Rear diff protector
-AC has a diff skid for the D44 out. Shrock is talking about releasing a new HD cover for the D44.
