#55437 - 03/01/04 09:25 PM High Lift mounting on Stock X
TremorX Offline
Loc: Waycross, GA
Has anyone mounted a high-lift jack on the roof or any other external mount point on a relatively stock vehicle (ie, stock rack, stock bumpers, etc). I like to keep mine with me but I hate leaving it in the back as it kills cargo room and mangles the carpet up. I don't want to get a loadwarrior yet (clearance issues) and have no plans to get a metal bumper on either end anytime soon.
Suggestions, pics?
Ian, didn't you do this? Since your old site is down I have nothing to study frown Does anyone have the pictures of the mighty-mount setup?
Don't worry, ma'am, I'm from the Internet!
#55438 - 04/01/04 08:23 PM Re: High Lift mounting on Stock X
Kerensky97 Offline
Loc: Utah
-Dustin
Xterra101.com
#55439 - 05/01/04 11:58 AM Re: High Lift mounting on Stock X
10 bucks in parts:
-Wing Nuts
-Washers
-Nuts
-Threaded rod
-Lok-tight
-Spray Paint
Go to page 2 and Scroll down the page and you will see it mounted on top.
Cardomain Site
P.S. I've been lurkin for a little over a year now, just thought i would finally say hello.
#55440 - 05/01/04 01:19 PM Re: High Lift mounting on Stock X
TremorX Offline
Loc: Waycross, GA
Thanks... I'm going to try the Mighty Mount one.. I'd like to avoid drilling the rails if possible.
#55441 - 05/01/04 11:56 PM Re: High Lift mounting on Stock X
Paul H Offline
Loc: Mt. Zion, IL
Originally posted by DarkwarriorX:
10 bucks in parts:
-Wing Nuts
-Washers
-Nuts
-Threaded rod
-Lok-tight
-Spray Paint
Cardomain Site
I love this idea. I will use it. Are the black things under the highlift on top of the crossbars rubber spacers?
My Blog
#55442 - 06/01/04 12:31 AM Re: High Lift mounting on Stock X
i8a4re Offline
Loc: Winnipeg/Calgary Canada
just out of curiosity.... where can you use a hi-lift on a stock x?
2003 Silver Ice Nissan Xterra XE
1997 Moss Green Jeep TJ
Homer: What kind of mileage does this thing get?
McBain: One Highway, Zero City
#55443 - 06/01/04 01:02 AM Re: High Lift mounting on Stock X
Not without bending something.
#55444 - 06/01/04 01:03 AM Re: High Lift mounting on Stock X
i8a4re Offline
[b]just out of curiosity.... where can you use a hi-lift on a stock x?
Not without bending something.[/b]
That's what I thought... the original post didn't quite make sense to me.
#55445 - 07/01/04 03:25 AM Re: High Lift mounting on Stock X
Paul Hartwig... No there not, just spray painted washers. the order i put every thing bottom to top is:
-Nut
-Washer
-Rack crossbar
-Washer
-Nut
-Washer/Rubber washer
-High Lift
-Metal Clamp(made from bent Aluminum)
-Wing nut
-Josh
#55446 - 07/01/04 06:16 PM Re: High Lift mounting on Stock X
hi-lift handle hugger Acool little doo-dad to eliminate rattle and wear..
I also used large rubber grommets on attachment points from my roof rack to the jack as well, they help a lot.(cutting out vibration and noise) [Smoking]
#55447 - 08/01/04 07:03 AM Re: High Lift mounting on Stock X
rfritz Offline
Loc: Indianapolis
Here is mine - I also have mounted the shovel to the hi-lift using some old Yakima parts.
#55448 - 08/01/04 01:32 PM Re: High Lift mounting on Stock X
KCX Offline
Loc: Kansas
Or on the back bumper:
www.hxoc.net
#55449 - 11/01/04 05:07 PM Re: High Lift mounting on Stock X
Xtracurricular Offline
Loc: Denver, CO
Since I snowboard, and the wife skiis, I use the ski racks in the summer for my hi lift and shovel. I have used it for lumber as thick as 2" x 8"s too. It is lockable, very secure, and fast. It seemed logical to me, but I have never seen anyone do the same thing. Maybe I stumbled onto something?
#55450 - 27/04/04 08:18 PM Re: High Lift mounting on Stock X
KCX,
Could you post some up close pics of you Hi-Lift mount. I'm interested in the mounts themselves and the positioning so you don't block the license plate. Thanks
#55451 - 28/04/04 01:08 PM Re: High Lift mounting on Stock X
KCX Offline
Loc: Kansas
Well, I have a rear bumper swing carrier now with my HiLift on the back, so that won't help with a stock rear bumper setup. BUT, here is a member from my club, Biohazard, who did the same.
www.hxoc.net
#55452 - 28/04/04 07:04 PM Re: High Lift mounting on Stock X
spooky1 Offline
Loc: Maricopa, AZ
TremorX, just talk to Travis, he has his on the roof rack with the mighty mounts. you can get them at almost any bike shop or REI.
Ryan
"Duct tape is like the Force: It has a dark side and a light side - and it holds the universe together."
#55453 - 05/05/04 05:41 PM Re: High Lift mounting on Stock X
I went through this description elsewhere in this forum, but I thought I'd place it here as well since it is more applicable here.
I used four mighty-mounts, two for each crossbar on the rack. The center bolt goes through the jack in the typical manner. I just wanted a little extra strength over the basic mighty-mount plan just in-case I got in an accident. I don't want to kill someone's kid with a flying jack. Hopefully I won't ever test it.
The picture is the view from the back. The metal plates go over and under the crossbar a little so that they might physically capture the jack if it started moving forward in a collision. Probably won't do much given the strength of the crossbars.
Anyway, here is my setup...
