#56999 - 23/06/03 08:31 AM Re: Fuel saver pro
SnoCone Offline
Loc: Edmonton
Anyone ever heard of Fuel Saver Pro? (http://www.fuelsaverpro.tv/default.asp?axel=2805). Unlike the tornado fuel saver, this one clamps on the fuel line and who knows what it does.
I luv'd my 240z too!
#57000 - 23/06/03 08:36 AM Re: Re: Fuel saver pro
Bogatyr Offline
Loc: Averill Park NY, USA
SnoCone,
As with any of these "snake oil" products, I'd tend to think that with all of the pressure auto manufacturers are under to increase CAFE numbers, they would jump at the bit to improve fuel economy by 27% by installing a $90 part. Since they don't, I have to assume it doesn't work.
I haven't checked to see if the FTC has slammed this company or others like it for similar products.
The best way to increase your fuel economy is to drive the speed limit, keep your vehicle in tune and to check your tire pressure regularly.
Bogatyr
2001 Nissan XTerra XE 40k
1984 Honda CRX 1.5 83k
1970 Land Rover IIa 88" 41k
1966 Land Rover IIa 109" 35k
#57001 - 23/06/03 08:59 AM Re: Re: Fuel saver pro
What is it made from?
It is a MATCHED PAIR of tuned custom sealed Neodymium Super inductors that generate a frequency resonance between its two faces.
What makes the FUEL SAVER unique?
Operates on the principle of RESONANCE, utilizing a double chamber frequency with phased frequency modulation.
FUEL SAVER sounds too good to be true!
HAHAHAHAHAHAHAHAHAHAHA! What a crock!!!
It IS too good to be true. They're goddamn magnets, which do NOTHING to gasoline.
P.T. Barnum was right,
#57002 - 23/06/03 09:17 AM Re: Re: Fuel saver pro
superjens Offline
Loc: North Vancouver
Neodymium
Whoa!
It has the power of the Matrix.
#57003 - 23/06/03 10:54 AM Re: Re: Fuel saver pro
rb42 Offline
Loc: McKinney
The only practical use for fuel magnets I can ever see is to trap stray metalic particles in a fuel filter. I've looked into the theory, and supposedly in a lab environment with glass tubing and no stray magnetic fields, you can improve fuel burn by aliging molecules and such... but put it in an engines environment and theres no way things stay aligned all the way into the cylinder...
#57004 - 23/06/03 06:19 PM Re: Re: Fuel saver pro
silverxglider Offline
Loc: Andes, NY
I rely on my heat shields to do this and get terrific gas mileage. My gas molecules are perfectly aligned at all times.
Boldly going nowhere.
