AFAIK there are no Nismo headers produced for the '00-'04 X.
Originally posted by X-Quad:
No headers? I want the Nismo's. Otherwise, i checked out SLR and thanks but no thanks. I still dont like torsion bars. So much restriction. I am planning on going with the TCF like before because it deletes the torsion bars and adds coilover long travel suspeension.
BTW, where did you find SLR stage 5? I only found 1,2,3. However, the setup IS nice on your X. That thing looks and sounds sick flying down through the sand!
I understand that coil overs are really cool and have their advantages. I just don't know what restrictions you are talking about? A spring is a spring. A torsion bar rotates and a coil compresses. Otherwise you are still talking about a spring. It's a little more difficult to dial in spring rates with a torsion bar but they is can be done just by switching them out. There are different diameter and length torion bars just as there are coils.
You can get massive amounts of travel out of a torsion bar set up as you can with coils. You can throw a coil and you can slip a torsion bar out of its anchor. I chose to stick with the t-bar set up since I wanted to maximise the stock design since I am using the stock pivot points. I also am able to use a larger volume shock since I don't have to fit a coil into the upper arm.
I's have to ditch the really trick and cool upper arms and/or use custom upper pivots if I wanted to switch it to coil overs. Are they cool and work well? Of course. They are the current primary choice in the desert. I guess I just like being different and I think it's cool that something old school can wrok so well.
I'm sure Nissan's engineers know more than I do. As a matter of fact last years overall trophy truck champion in SCORE was driving a truck suspended with t-bars front
and back.
The Stage 5 SLR is a long travel suspension that has been fixtured to reduced costs so that you get what is esentially a custom suspension system with the advantages of being able to produce it as a production line.
