#573217 - 08/06/10 11:28 AM 2000 XE stereo wiring help
kaqy Offline
Can someone tell me what colors run to the rear speakers? Trying to get everything back to factory from the previous owner and just having fronts sounds like an AM station all the time...:) Thanks!
#573218 - 08/06/10 11:38 AM Re: 2000 XE stereo wiring help [Re: kaqy]
e207 Offline
Loc: Ashland, PA U.S.A.
I do not know what colors are what, but if they were already cut for another install, the easiest way to find out what is what, is to disconnect your battery, then use a 9volt, AA, D or C Cell battery and connect two wires to it, it will make a small "pop" or "click" sound when you hit the right wires, it will also help you find out for sure which is left and right. just dont forget to disconnect the car battery, so as not to connect wires that shouldnt be connected!
2002 SE/SC R.I.P. March 2015
Bielstien's
Shrock Sliders
Captain 38-90
#573269 - 11/06/10 12:35 PM Re: 2000 XE stereo wiring help [Re: e207]
FoxFive0 Offline
Loc: PNW, WA
That would work however then you run the risk of wiring the speaker backwards. The only way that trick works is if you can see the speaker moving outword then you know you have positive to positive and negative to negative. If you wire it backwards the speaker will project the sound into your door. SO the best thing to do would be to try and find a wiring diagram. Unless you still have the time to search and see every wire.... which is tough.
May I ask though why you would want to return to factory?
“Every good citizen makes his country's honor his own, and cherishes it not only as precious but as sacred. He is willing to risk his life in its defence and is conscious that he gains protection while he gives it.”
Mobile Elec Cert Pro Silver Level
