#628036 - 11/10/06 09:18 AM Changing XP Language
I have a customer that wants to change his windows XP Home base language from Russian to English. It is a legit version as it comes from an OEM laptop manufacturer (toshiba). He doesn't just want to be able to type in english, he wants to be able to run the laptop as if it was an english computer, while retaining some of his currently installed programs in cyrilic. Any ideas out there...?
#628037 - 11/10/06 09:43 AM Re: Changing XP Language
I ran into that before way back in the day. I wanted to change mine from Russian to English and I ended up reinstalling windows, the Enginlish version, that is. And then I found a program that I was using so that I could run some of my Russian soft. still.
This was way back in the day and sory I I wasn't really helpful.
#628038 - 11/10/06 09:47 AM Re: Changing XP Language
hattrik21 Offline
Loc: Lewisville, Texas
Start | Settings | Control Panel | Regional Settings.
On the Advanced tab he needs to change the drop down box to English. Then on the Languages tab I belive he needs to do the same.
He might need a language pack but I'm not sure.
SWXC Member # 65
TMTC Member # 1795
www.Texas-X.net
www.TheNewX.org
#628039 - 11/10/06 09:49 AM Re: Changing XP Language
This doesn't work as he will be running windows natively in russian, but have english capabilities. He basically wants it the other way around.....
#628040 - 11/10/06 03:02 PM Re: Changing XP Language
Chris Mc Offline
Loc: St Charles, MO
There are different versions of XP distributed in different countries (they have different SKU's). You will need to reinstall with the English Language version. Occasionally, they sell products with a MultiLanguage SKU, but I didn't find one for XP (at least under Volume Licensing). You can try contacting Microsoft to see if they'll let you swap, but I doubt you'll luck with that. Most likely you'll be buying a new copy.
#628041 - 11/10/06 04:07 PM Re: Changing XP Language
Yeah that's kind of what I figured as well, but thought someone else might have had a cure for this.
Thanks for the help guys smile
