#636651 - 14/03/05 12:49 AM Computer (ECM) Upgrades?
Curious if anyone has tried out the A/C $350 computer upgrade and can post results using this mod. Thanks!
A /C (4x4parts.com) Computer Upgrade with DST [Freak]
#636652 - 20/03/05 12:23 AM Re: Computer (ECM) Upgrades?
ECU upgrades are only as good as the mods you have installed. They are usually programmed accordingly, and most often the "last piece of the puzzle." From the mods listed in your sig, I wouldnt recommend dropping the $350 on one, I doubt you would even notice a difference. (It may crispen up the throttle response a bit).
JET is one well known ECU re-programmer http://www.jetchip.com/, and here is an article with good results from them:
http://www.fourwheeler.com/projectbuild/129_0303_xt/
Upgrades to a vehicles ECU are usually needed and highly beneficial when tuning a forced induction application and increasing the boost from stock.
What else do you have done to warrant an ECU upgrade?
You may search around locally, in hopes of finding a shop that can install a piggyback "engine management system" and tune it on a dyno. That method is more worth the money than blowing it on some generic chip, and most of these systems are re-programmable with a laptop, in the event you want to change or tweak something.
Have a look at these links for more information:
http://www.haltech.com
http://www.aempower.com/product_ems.asp
http://www.motec.com/products/ecu/control.htm
There are more out there, but those are the ones I know of off hand.
#636653 - 20/03/05 07:22 PM Re: Computer (ECM) Upgrades?
Well I don't have many of the mods listed becuase I have the parts, just haven't had the time to install anything. I have a new locker (only LSD) to install, 3" Calmini lift, and possibly on the way, SLR headers (I know, I've read the posts about the CARB exemption problems and extra Heated Air Sensor bungs). I also have a Shrock bumper on the way. The only real reason I was trying to see if anyone had tried the DST ECM upgrade was to find out if they had corrected a change in tire size (I'm either going to 32.7" TSL Thornbirds or 33" BFG A/T KOs) to get an accurate reading out of the speedo. I'm just going to get the Dakota Digital chip and test that one out. Thanks for the response!
