#649163 - 02/03/03 12:44 PM Quick question for mechanics............
Fullback#40 Offline
I was doing the ol flush & fill on my X and took out the drainage plug on my radiator and then went and ate lunch. When I came back out I pulled the drain plugs off of the block and there was hardly any drainage from them. Will all of the coolant drain out through the radiator? , i was parkred in my driveway and it slopes down toward the engine. Also what kind of antifreeze do most of you use? i live in FL. so I just used the prestone premixed. Also is it normal for the block drainage plugs to be tight at only half way in. Thats how they were when i took them off to from the factory. [Wave]
http://xterra.sluder.net/board/index.cfm NEW SIGHT CHECK IT OUT TOO!!
#649164 - 02/03/03 04:04 PM Re: Quick question for mechanics............
XmtbX00 Offline
Loc: Denver
How did you get the block bolts out? I tried about a month ago and had not luck.
Thanks,
Ron
White 2000 SE
#649165 - 02/03/03 05:30 PM Re: Quick question for mechanics............
Fullback#40 Offline
I sprayed them down good with blaster waited about half an hour and then used an impact rachet with an extention on it. It was a royal pain in the ass. Next time they will stay in. [Argue]
#649166 - 02/03/03 05:47 PM Re: Quick question for mechanics............
might want to try adding some water wetter to your radiator...You can read more about it in the link below...
http://www.redlineoil.com/redlineoil/wwti.htm
You can also buy it at most Pep Boys stores... wink
#649167 - 03/03/03 12:45 AM Re: Quick question for mechanics............
*paul Offline
Loc: New Zealand
Presumably you drained the same amount it took to fill it back up again.
-Paul
2007 Nissan X-Trail
New Zealand (ex San Diego)
