#650377 - 03/07/01 08:12 AM Help Removing Trim Piece on Driver's Door Post
rbbarker Offline
Loc: Houston, Texas
I need to remove the trim piece on the driver's door post. I'd like to run a wire under it. It's the piece inside running from the dash up near the visor. It has a handle on it. I tried removing the handle, but the piece still wouldn't budge. Any ideas?
Boyd Barker
SWXC#46
2001 Goldrush SE 4x2 w. leather
#650378 - 03/07/01 11:43 AM Re: Help Removing Trim Piece on Driver's Door Post
miket Offline
Loc: big island, hi
Assuming there's no hidden screws....
It's probably got snap rivets holding it on. Carefully pry up an end. You'll feel where the rivets are. Work your fingers back till you find the first one. Pull straight out with your fingers on either side of the rivet. Do the same with the rest.
I can't remember whether there are any panels overlapping the one you want to remove. If so, take them off first.
mikeT
2001 SE 4X4
Rain+Dirt!
2001 SE 4X
Rain+Dirt!
#650379 - 03/07/01 09:43 PM Re: Help Removing Trim Piece on Driver's Door Post
spike Offline
Loc: North Bend, OR
I ran the wire for my radar detector under the same place. I couldn't manage to get the entire trim piece off, but once the handle is removed, it can be pulled up enough to easily tuck the wire underneath.
'01 SE Just Blue 4x4
-PNWX member-
-PNWX member-
#650380 - 04/07/01 06:40 AM Re: Help Removing Trim Piece on Driver's Door Post
rbbarker Offline
Loc: Houston, Texas
You must have tucked it under from the windshield side, right Spike?
Boyd Barker
SWXC#46
#650381 - 04/07/01 03:50 PM Re: Help Removing Trim Piece on Driver's Door Post
rbbarker Offline
Loc: Houston, Texas
Anybody else have any ideas?
Boyd Barker
SWXC#46
#650382 - 05/07/01 01:43 AM Re: Help Removing Trim Piece on Driver's Door Post
spike Offline
Loc: North Bend, OR
Actually, I believe I tucked it in from the door side.
-PNWX member-
-PNWX member-
#650383 - 05/07/01 03:22 AM Re: Help Removing Trim Piece on Driver's Door Post
PoqFFEMT Offline
Loc: Poquoson, Virginia
I went ahead and bought a tool from Crutchfield made to remove those "snap rivets" It looks like a elongated and flattened out fork. all you do is wedge it between the panel ant the body and gently pry it up. I've yet to damage the panel, truck or the rivet with this tool.
~John~
2001 Xterra SE 4X4 Auto
Just Blue
Do you have stairs in your house????
[This message has been edited by F15 Tech (edited 07-05-2001).]
~John~
