XOC wrote:
Which gear oil do you want to check, tranny, transfer case or diffs ?
I'm looking to check the tranny [primarily] oil, although knowing how to check the Diffs and transfer case (that is for the 4x4, correct? If it's the main engine oil, then ignore that, I'm not that big of a moron, although I feel dumber every morning
) would definately be good as well. Sorry for not specifying
I meant to, but just call me absentminded.
All are pretty much the same. You can check the oil level by removing the filler plug, and checking with your finger (it should be just below the hole).
Ok, here is where I could use some direction. Where are the fill plugs located for each?
(OK, I'm a newbie so flame if you wanna, but I've searched the net and the owner's manual, and haven't gotten anywhere with those efforts :o)
Also, do you have any brand preferences for replacing the oils (in either the diffs or transfer case)
Thanks for your help already, and for any additional help you can provide.
