#653621 - 30/10/06 09:33 AM Replacing Screws in body armor
First - insert standard disclaimer on search as well as blanket apology if I just didn't search well.
Ok - so when changing my oil recently - one of the screws bonding that skid plate/body armor has removed itself. There's now a little bit of vibration that I hear from down under and I'd like to replace it. Anyone ever done it? Thoughts/recommendations?
Should I check "the google" for a part number?
Thanks in advance... [drink] and take a beverage or two out of petty cash for your trouble...Z
#653622 - 30/10/06 10:03 AM Re: Replacing Screws in body armor
Scews? At least you didn't call your X a car. My truck uses bolts.
Yes there have been threads on this. If the threads are still good go to Autozone or similar place and buy some replacement bolts. If the threads are gone or damaged drill the hole out to the suit the next size bolt then drill and thread it then insert new larger bolt.
