#654442 - 04/03/04 10:25 PM Removing the Headliner
Buckshot Offline
Loc: Georgia
I am planning on running a CB antenna cable from the front to the rear cargo window on the drivers side. I will need to partially remove the headliner to install the cable. I am just curious if anyone has had experience removing their headliner and replacing it without any permanent damage?
Cheers
"Everybody to the limit, the Cheat is to the limit, everybody come on Fhqwhgads!"
#654443 - 04/03/04 10:30 PM Re: Removing the Headliner
Aero Steve Offline
I just pulled loose the plastic trim on the sides and tucked my cabling up over the headliner. I never had to pull the headliner completely out. I've got CB and Sirius antenna wires on the passenger side and a GPS antenna wire on the driver side.
#654444 - 04/03/04 10:32 PM Re: Removing the Headliner
ChuckH Offline
I don't recommend removing the headliner at all, and the good news is you shouldn't have to. I don't remember exactly how they all come off, but you should be able to remove or pull back the trim all along and just kinda push the antenna cable in under the headliner at the edge. I went down the right side with my XM wires and that's all I did.
